headlight dimmer switch issue
Discussion in 'The Hokey Ass Message Board' started by Flat-Foot, Aug 20, 2012.
  1. Flat-Foot
    Flat-Foot
    from Locust NC
    I have had a small issue with the headlights since day one. With the switch in one position i get all four lights. When I click it I get one regular light only. I tried a new switch and that didnt do it.
    Any ideas?
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Have you tried changing out the one bulb that doesn't light up when it should ? Lights can do crazy stuff sometimes.
    Don
  3. fiddy
    fiddy
    Low beam filament burned out on one light?
  4. Flat-Foot
    Flat-Foot
    from Locust NC
    Well its 4 individual lights. They all light up when the switch is in one position.
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    That may not matter. Have you changed that bulb out ?
    Don
  6. Flat-Foot
    Flat-Foot
    from Locust NC
    Well I just went out there to switch another bulb and at first it didnt work. The I noticed one of the wires in the plug was loose...........
    Im gonna go sit in the corner now.
  7. Flat-Foot
    Flat-Foot
    from Locust NC
    Thank you to those who replied.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    Stay in the corner until you understand what you did wrong.
  9. Mr48chev
    Sometimes the really simple things will beat your ****.
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    Haha, don't feel like the Lone Ranger, we've all done similar things.
    One time I pulled up in front of the windows at a 7-11 and dimmed my lights. All four went out. When I hit the dimmer none would light up, so I figured the switch had to be bad because the odds of all four bulbs blowing at one time was impossible.
    After an hour standing on my head under the dash changing the switch they still wouldn't work. :confused: You guessed it..........ALL 4 BULBS HAD BLOWN and when I replaced them they worked fine.:eek:
    Car's are strange animals.
    Don
  11. 327-365hp
    327-365hp
    from Mass
    Yup, like forgetting you shut the fuel pump of last time you drove it, then wondering why it won't start. :eek:
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
  13. Flat-Foot
    Flat-Foot
    from Locust NC
    Thanks for the wiring diagram!
    Sent from my DROID device using the TJJ mobile app
  14. d2_willys
    d2_willys
    from Kansas
    You have to remember that the two outer lamps have both a high and low beam filament, where the inside bulbs are strictly high beams. One of the bulbs has a bad connection to the low beam filament or the bulb is bad.
