Headlight gurus?
Discussion in 'The Hokey Ass Message Board' started by Rusty, Feb 9, 2006.
  1. Rusty
    Rusty
    A local welder calls me a while back and says he has some lights for me. I go check them out and they are some perfect looking guide headlights. No tags but there is a guide stamp on the back. The only problem is They are setup to be mounted sideways or should I say the mounting stud is on the side and not the bottom. They are guides with the marker lens on the top or if mounted like a highboy the marker will be on the side.. Anybody ever seen some of these. Was gonna try to run them but the lense will be on the sides. I quess it would be different. Any idea what they are from? Heres some pics
  2. I don't know what they're from but htey'd be perfect for a bike project I'm starting.
    They appear to be a sealed beam so I think you could rotate the lamp to the right orientation.
    How are the marker lights attached? Are they spot welded on? Maybe you could drill out the welds, reposition them and weld up the remaining holes. That or perhaps the mounting stud area could be cut out and repositioned, then use the metal from where they're going to patch the hole from where they came.
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    ...hey Bubba. Those are for COE trucks and mount to the side of the radiator shell, so the turn signal stays on top. Just remount the turn signal to the top and run 'em...
  4. Bigcheese327
    Bigcheese327
    Those would be perfect if you wanted to run them hung off the side of your grilleshell, tractor-style. I'll bet you can re-clock the marker lights if you look carefully at how they're ***embled. Aside from the side-mounting and the fact that yours have trim rings, they look just like mine. 7" sealed-beam, right?
    Not to hijack, but anybody know where I can get trim rings like that? I asked a long time ago, but I've forgotten the answer.
  5. gassy cowboy
    gassy cowboy
    from Tucson, AZ
    These look like headlights that came from a 36 chevy. They mount on a stand and attach to the side of the grille shell. The indentation looks exactly the same as my 36 chevy headlights.
  6. Slag Kustom
    Slag Kustom
    you can get some thing similar aftermarker for a harley that mounts almost the same way . any harley with the enclosed headlight nazel
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    Roy Olsen in Sioux City Iowa repops the trim rings and the retainer rings for Guides and BLC headlights. Go to ebay and search this auction:4608928297. His ebay name is ROOM4MORE. He doesn't have the trim rings up for auction right now, but contact him and he'll hook you up. I've got a set on the coupe and they look great.
  8. Rusty
    Rusty
    I know the saying that cant never could. But where the marker light mounts there is a indentation or stamp in the rim that it sites in. So I f I rotated that indention would always be there. May run them ****ed over or run my mount up to it straight. Either way I think the would be cool. What do yall think? Was gonna use some old headlight bars to make a tie between the two lights and run as is.
  9. man-a-fre
    man-a-fre
    Off a coe like 3w larry said.
  10. DrJ
    DrJ
    Why not run the mount at the bottom and the marker/Tsignal light on the side?
    You can turn the bulb by filing a new notch in the bucket rim for the bulb's locator "bump"
    Just be sure and drill a new drain hole at the new bottom or they will rust out.
  11. 286merc
    286merc
    from Pelham, NH
    Not at all specific to a COE. I have a virtually identical set that came off a 36 Reo dump truck.
  12. the-rodster
    the-rodster
    I've got a set of those, handy just for replacement markers and gl*** :)
    So THAT's who ROOM4MORE is.
    He bids on every set of Guides or BLCs on Ebay.
    He must be a headlight *****.
  13. The37Kid
    The37Kid
    I'll freely admit that I may be the only guy here that doesn't like the look of Glide headlights with the turn light on top, just looks like a pimple on a perfectly good light. Why not mount them the way they are and have the turn light on the side?:)
  14. rusty1
    rusty1
    I've got one (1) of those lites if anyone needs one...$60.00 plus shipping.
    I think it's off a big truck like a Reo or White. Mine has a cast bracket that bolts onto the mount bolt.
  15. tommy
    tommy
    I guess I'm the only one that would carfully cut out a square around the mount area, make a pattern for a template to cut the bottom out and reweld the patch where the mount used to be. If you take your time it should be reasonably easy with very little body work. but that's just me.
  16. arkracing
    arkracing
    Don't cut them up. - they are different.
    Run them with the markers on the side as-is
  17. grumper
    grumper
    I don't want to highjack the thread, but does anyone know where I can find a pair of those marker lights? I have a pair of lights that are missing the markers.
    grumper
  18. Crusty Nut
    Crusty Nut
    I like them because they aren't like every other set of guides I see. Either run them as is or find another set, please don't cut them up so they look like everyone else's.
  19. Dirty2
    Dirty2
    Someone on here makes the lenses.
  20. ol fueler
    ol fueler
    I don't think they will do at all , no matter what you do to them . Send them to me & I'll dispose of 'em fer ya!!
    dave
  21. Slide
    Slide
    I'm with those who are thinking they could still be cool with the markers on the sides... as long as you can position them so the tires don't rub the markers off!
    Could you run a headlight bar across your grille, mounting the headlight studs into the bar, then some mounts that raise that bar up off the frame rails?
  22. man-a-fre
    man-a-fre
    Not at all specific to coe but thats what the three sets i have like them came off of.Im sure that an early coe is an application for those headlights
  23. Southfork
    Southfork
    Well, maybe, but on my '38 COE they mount on the fender so the mounting post is on the bottom of the 682 C buckets.
  24. man-a-fre
    man-a-fre
    Found another set today like em on an old dodge powerwagon.Not for sale though.
