Hot Rods Headlight issues 33 Ford
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Nov 14, 2017.
  1. guy1unico
    guy1unico
    This just started happening...everything worked just fine until...
    When I turn on the headlights the ignition dyes and headlights dont work.
    ....there is no fuse.
    Could the solenoid be shot...looks pretty old.
    The car has a new 12 volt electronic ignition and I'm sure this is a 6 volt solenoid...but it worked fine and it still starts the car unless the headlights go on.
    What do you think?
    Thank you,
    Guy
  2. greybeard360
    greybeard360
    It starts and runs, but dies when you turn on the headlights?
    Sent from my Moto G Play using The H.A.M.B. mobile app
  3. HOTRODPRIMER
    HOTRODPRIMER
    Check your headlight switch. HRP
  4. guy1unico
    guy1unico
    Yes ...to greybeard360
  5. jcmarz
    jcmarz
    from Chino, Ca
    Leave tour headlights off, problem solved[emoji23][emoji23][emoji23]
    Sent from my SM-J700T1 using The H.A.M.B. mobile app
  6. greybeard360
    greybeard360
    Do the headlights work when you turn them on? Does the ignition have to be on for headlights to work? How bad of shape is the wiring?
    Too many questions that need to be answered before anyone can guess at the problem.
