Headlight Mounting
Discussion in 'The Hokey Ass Message Board' started by keeper, May 9, 2012.
  1. keeper
    keeper
    from So Cal
    Does anyone know where I can find a set of these bolts, nuts, clips. I am tring to piece together a pair of 35 Ford commercial lights that were pretty rusted out.
    They are 11/16-18. The thread size is not important to me but the rounded head and the rectangular shoulder are.
    I tried Roy Nacewicz but he doesn't have them, actually he said he has never seen them reproduced. Any help would be appreciated.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Those lights were used on 35-37 pickups, panels, etc. Ford never offered repair parts and the market would be too small to reproduce them. You're looking a friend with a lathe for the bolts and another set of lights for the clips, I'm afraid.
  3. keeper
    keeper
    from So Cal
    VAPHEAD to the rescue.
  4. The37Kid
    The37Kid
    I'd get a couple of carriage bolts from the hardware store and modify them to fit. Bob
  5. Sumfuncomet
    Sumfuncomet
    That's all I did37 kid said.....carriage bolts from hardware store is all you need, you may have to grind the square shoulder slightly is all. Cost three bucks for two....DIY!
  6. I repaired some broken '35 car bolts that were hollow so the wire would pass thru. I took some 5/8" DOM tubing and threaded the outside 5/8-18, cut it to length and welded it to the head portion of the original bolt.
    Seemed easier to do this way than to try to drill a new bolt or
    reroute the wires externally.
    I have also seen the shank sanded down some and re-threaded with 5/8-18 instead of the original 11/16.
  7. bgaro
    bgaro
    you'll have to make 'em. never seen anything like those around.
