Headlight Mounts/Fenderless A
Discussion in 'The Hokey Ass Message Board' started by tmacracin, May 27, 2009.
  1. tmacracin
    tmacracin
    Lets see your headlight mounts. I'm looking for ideas for my fenderless 28 Model A pickup. I have a set of F-100 shock mounts on it now that I was thinking of welding some cups on them for headlights also. BUT I also have a set of friction shocks I would like to run instead so I would need to build some seperate headlight mounts
  2. Here is the way I did mine.
  3. trad27
    trad27
    here is how i did mine, i had the bar to them so i just cut it off at both ends close to the mounting bowl. welded the ends pointing down so they can now mount to the frame rather than the fenders. i had to do a little heating and bending but fit good and still have a bar going across to mount a 32 v8 logo to.
  4. Wildfire
    Wildfire
    Did mine very similar to Trad27's. One mistake I made was putting the rear bolt hole through the crossmember. With the spring and everything installed, that is a very small space to get even a box-end wrench. The above position looks much easier.
    Make sure you have your shocks mocked up. I also ran into headlight interference issues.
  5. AV8Paul
    AV8Paul
    Here are a couple of shots of my set up. I took an "A" HL bar and cut the ends off. Then I welded two hollow tubes to the feet and that to the the bar. The wires go thru the tubes and come out inside the frame horn.
  6. chaddilac
    chaddilac
    Here's mine.. I utilized the radiator support and a model a bar...
    also did a thread on it....
  7. Nobodys Hero
    Nobodys Hero
    from New Jersey
    heres mine. Split a 32 V8 bar at the ears and bent the horns over
  8. 29 bones
    29 bones
    from so cal
    I used the headlight bar as a shock mount as well....
  9. stillkruzn
    stillkruzn
    from Conway, AR
    Here is mine...
  10. Rich Wright
    Rich Wright
    Made from 30/31 fender braces and an old A tie rod.
  11. 067chevy
    067chevy
  12. 067chevy
    067chevy
  13. rick finch
    rick finch
    Ha...I know you, you're a pinstriping wizard! See you in August for our BBQ in Austin,Nv.:D
  14. 31ACoupe
    31ACoupe
    A buddy used a couple flathead rods, cut down to fit and they look way cool.
  15. hotrod-kustom
    hotrod-kustom
    Hi Tim
    wonder about your Frame/ Steering box looks from this photo not so strong.
    WV Transport up to 67 have a markets best Steering box to use and easy to mont in a frame
    Only my 02
  16. tmacracin
    tmacracin
    That looks good! I like them when they are mounted a bit lower like yours
  17. 29Jay
    29Jay
    from Ft Worth
    We should do more.... I like it, I like...
  18. RAY With
    RAY With
    Actually all of them have merit. I like each one and see the only hard part would be to choose just one--Ideas and sharing makes HAMBERS top's
  19. Equipped28
    Equipped28
    all my dad did is he made a pair of bat wings and mounted the shocks and the headlights on them ;)
  20. Sparkswillfly
    Sparkswillfly
    from Colorado
    Pete & Jake.
  21. Tenacious A
    Tenacious A
    from Willis Tx
    From speedway I think
