Projects Headlight wiring
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Nov 9, 2024.
  1. IowaTom
    IowaTom
    Guys - Working on a friend's '52 Willys Aero and not only re-wiring but going to 12v. The shop manual didn't color code the schematic and I'd like your input on which of the two spade connectors is high and low beam. (The ground is obvious) Thanks much!
  2. BJR
    BJR
    Grab a sealed beam headlight bulb and some alligator clips and a battery. Not hard to figure it out yourself.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
  4. pprather
    pprather
  5. squirrel
    or, to try to minimize confusion.... green is high beam, black is ground, tan is low beam
    osage orange and ramblin dan like this.
  6. goldmountain
    goldmountain
    About a week ago, I turned on my headlights and noticed that the right one looked a bit dim. Took off the trim ring for a look and noticed that the last time I plugged the connector on, I had rotated the plug 90 degrees. It would work this way on either low or high beam since it would be a complete circuit. Sometimes I need to pay attention to what I'm doing.
