Headlights flickering. WTF?
Discussion in 'The Hokey Ass Message Board' started by sociallydistorted, Aug 3, 2007.
  1. sociallydistorted
    sociallydistorted
    Here's the scoop:
    1960 Ford F100
    Headlights stay on if I'm not driving but after about 20 minutes of rolling down the road, they flicker off and on. I've checked the wiring. Nothing is loose. Checked the switch. Everything seems in order.
    Help a brotha out
  2. Berky
    Berky
    It sounds like the circuit is getting to hot and loosing connection. I had the same problem with my car and the relay was going out. I replaced the relay and all was well.
  3. sociallydistorted
    sociallydistorted
    I'm going to act stupid for a second. Any idea where the relay is? I'm no electrician guru.
  4. Revhead
    Revhead
    from Dallas, TX
    most headlight switches have their own circuit breakers. just a simple bi-metallic tab and two contact points.. it might be getting hot and turning them on and off itself.
  5. de-generator
    de-generator
    Check the dimmer switch. When they start to go out they will do this.
  6. sociallydistorted
    sociallydistorted
    Yeah, their is a big*** breaker on the backside of the switch. I re-soldered all of the loose wires when I first got the truck.
    I'm thinking it is the dimmer switch because when I turn it to dim the dash lights, it just turns them off. There is no "DIMming".
  7. triple check all grounds ..to engine ..to frame ....to dash
    something is loose... even unsupported wiring near the headlite
  8. S.F.
    S.F.
    Id check the grounds man, Had that happen to me and it was just a bad ground.
  9. Mudslinger
    Mudslinger
    Dimmer switch, Headlight switch.
  10. sociallydistorted
    sociallydistorted
    Cool. I'll check all of the grounds and switches and everything again tomorrow. Thanks guys
  11. If your running Halogon bulbs and p***ing power through a 60's style light switch instead of a Relay, your probably smoking the switch. Sounds Switch related to me. A bad ground will generally make a light go dim but seldom flash off and on, that's a bad contact flashing lights or a Circuit breaker tripping off and on.
    The Wizzard
  12. Section 8
    Section 8
    from AZ
    The dimmer switch is for high/low beam.
    If your dash lights won't dim, that's the headlight switch.
  13. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    same thing i was thinking some time the plastic or Phenolic melts or wears away and starts doing this
    it has happened to me in the past
  14. Your headlight switch's circuit breaker is "PLUM WORE OUT"!
    You could replace the switch and/or do this.
    http://www.rowand.net/Shop/Tech/WiringHeadlightRelays.htm
    You should do the relay install and get brighter lights to boot as the voltage drop from all that wiring to and from the dash will make them dim. Often by doing this you won't even need to replace the switch as it is only operating the relay's after.
  15. punkabilly1306
    punkabilly1306
    from ohio
    my old pontiac did that and turned out to be the dimmer switch
  16. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    I have a '60 F100 too, and I had the same problem. I replaced the headlight switch and it cleared right up. The circuit breaker is inside the switch.
