Hot Rods Headlights with Built-In Directional Lights
Discussion in 'The Hokey Ass Message Board' started by 19Fordy, Apr 27, 2022.
  1. 19Fordy
    19Fordy
    I just want to say "THANK YOU" to all the folks who responded to my post
    and to those who posted photos. It really helped my decsion making procees which is
    still pending.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I used a old set of fog lights for driving lights/turn signals on my '32 pickup. HRP
  3. 19Fordy
    19Fordy
    HRP: Those fog light directionals look just fine.
    clem and lothiandon1940 like this.
  4. Just Gary
    Just Gary
    Stock Model A fluted lenses, rings, conduit & housings,
    with new integrated CW Moss/Vintique headlight/turn signal guts.:cool:
  5. lothiandon1940
    lothiandon1940
    ^^^^Beautiful^^^
    Just Gary likes this.
  6. cfmvw
    cfmvw
    Something that I noticed on new vehicles is one headlight will turn off with the turn signal depending on which side is blinking. Would definitely make the turn signal bulb inside a headlight more visible on a hotrod.
    rdscotty and lothiandon1940 like this.
  7. 56MercMan
    56MercMan
    Our 2001 Vehicle got a recall back in 02,03 where they installed a device that shut off the headlight on the side the blinker is blinking on. I believe since then all new cars do that. Actually maybe it is just the vehicles that have the blinker in the headlight housing as my 2005 truck does not do that but the HL is a different housing then the blinker.
  8. blue 49
    blue 49
    from Iowa
    Maybe things have changed or it doesn't matter to you but when aftermarket LED "sealed" beams were first out, the ones I saw were not DOT approved. My 2 cents, I'm not a fan.
    Gary
  9. BamaMav
    BamaMav
    from Berry, AL
    My Lincoln came with factory signals and foglights. I used the the original turn signal for parking lights, and put amber sealed beam trailer lights in the fog light housings. Now I have large easily seen turn signals up front that don't look out of place. The 4" trailer lights fit in many original 6volt fog light housings without many modifications needed.
  10. flynbrian48
    flynbrian48
    In my '36 and my '34 I put a dual filament socket in the headlight reflector and put amber bulbs in them for park/turn signals. The looked fantastic as parking lamps, and worked fine as turn signals, although they were hard to see at night with the headlights on for oncoming cars. LED's are brighter but at the time they weren't available in amber. I always use LED taillights after our Pontiac wagon was rear ended. The brighter the better.
    41rodderz likes this.
  11. Dont have any pictures ,but on my guide headlights with the parking light on top , I went to a stain gl*** shop and bought yellow gl*** stain ,worked awesome
  12. 41rodderz
    41rodderz
    from Oregon
    I believe they have DOT markings now .
  13. 1930ModelA
    1930ModelA
    Jim, got these on the ‘36, from Rodtiques. They are incon****uous and retain the stock look. You’ve seen them and didn’t even notice, so that tells you something. B5A7EC4C-64C7-41B5-96D3-B485B77CF625.jpeg 84D53C74-2436-4A6A-9EEE-AB02EA80693F.png
  14. A-Bomb
    A-Bomb
    Hi, where did you get the signal bulb sockets ? Thanks
  15. pprather
    pprather
  16. pprather
    pprather
  17. pprather
    pprather
  18. willys36
    willys36
    I like to build these little circuits that flash the headlight low beams. A lot cheaper than those ebaY items!!!! 3 5ohm 50W power resistors, a couple Bosch relays, and terminal strip.
    treb11 likes this.
  19. pprather
    pprather
    I have "flash to p***" using a VW electronic dimmer switch.
    rattlecanrods likes this.
  20. Bandit Billy
    Bandit Billy
    I used the domed lenses on my 41 PU. They stick up and stand out better than the low-profile lenses.
    On my roadster I committed a slight fashion faux pa as I used cowl lights on a fenderless car :eek: and I wired them as turn signals as well as amber running/turn signal bulbs in my 34 reflectors. It's a bit bright I have been told.
  21. Jkmar73
    Jkmar73
    from Tulare, CA
    On my Model A, I used new reflectors from Brattons and stock lenses. For bulbs, I am using the new led bulbs that don’t require adjusting. The turn signals are in the reflector, but I am using single element led bulbs from Holley. They light up orange, but when they are off, you can barely see them. They light up nice when the headlight bulb is on. IMG_0430.jpeg
    Algoma56, pprather and Just Gary like this.
  22. @Jkmar73 are you using the Logolight? brand headlight LED bulbs?
  23. Jkmar73
    Jkmar73
    from Tulare, CA
    Yes, I believe those are the ones. I ordered them from Brattons with the other stuff to rebuild the headlights. They are a nice white color, just have to drop them in. No focusing like the other ones.
  24. rattlecanrods
    rattlecanrods
    Dude!! Many thanks. I keep grabbing the brights to flash thinking it'll do something. Now I can fix that!
    pprather likes this.
  25. 34Phil
    34Phil
    I added Dorman 54427 1999-2010 F350 amber fender clearance lights for turn signals in the fender fronts with Standard S697 pigtails. One wire to lights and one to turn signals as single filament. 1-1/2"x2-1/4" football shape. Drill a hole and file two notches. I had made a can to tunnel them but decided to surface mount so just welded reversed can in.
