Projects Headliner one piece
Discussion in 'Traditional Hot Rods' started by John Kraft, May 23, 2022.
  1. John Kraft
    John Kraft
    Making one piece headliner for my 33 Ford Tudor off of Marcel filled roof
  2. 41rodderz
    41rodderz
    from Oregon
    Cool . As long as you got the dimensions figured out , looks golden .
  3. Henry27T
    Henry27T
    How are you making an inside part on the outside of the roof, Ar you planning on sectioning it in both directions?
    i will be making a one piece headliner for my 27 coupe
    Flathead Dave and Johnny Gee like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Looking forward to seeing how it turns out. HRP
    Langan likes this.
  5. John Kraft
    John Kraft
    Yes
    dana barlow likes this.
  6. HotRod33
    HotRod33
  7. Roothawg
    Roothawg
  8. Cool! Cole did this ones headliner in steel, he said gl*** would have been much easier to work with.
    chevyfordman likes this.
  9. goldmountain
    goldmountain
    Will that fit through the windshield hole?
    Johnboy34 likes this.
  10. lippy
    lippy
    from Ks
    Now just use that as a mold and lay up one on the inside of that one. Lippy
    Tman likes this.
  11. John Kraft
    John Kraft
    Here it is rough cut need to section
    oliver westlund likes this.
  12. Nice work! Looks like a real good layup
  13. John Kraft
    John Kraft
    Only used two layers and one extra coat on top with resin still flexible enough to squeeze in fron window
  14. harpo1313
    harpo1313
    from wareham,ma
    Looks great, might even squeeze it through the door opening on an angle.
  15. dmar836
    dmar836
    Anything composite I'd want to vacuum or it can be a lot of unnecessary weight. Looking forward to seeing it go in.
    D
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    Great idea. Please show us steps as you go.
  17. indyjps
    indyjps
    Please show steps, attachment points, mold process. Very interested.
    Are you planning smoothy, or use this as base for upholstery?
    I had OT project on rotisserie, considered a 2 pc with a center feature to cover the seam, didn't do it.
    Doing one during a top chop would be ideal :)
  18. John Kraft
    John Kraft
    Base for liner upolstery
    indyjps likes this.
  19. dmar836
    dmar836
    Gotta be honest. "Traditional" sailed a long time ago.
    hemihotrod66 likes this.
  20. indyjps
    indyjps
    Fibergl*** is traditional :D or at least pre 1965.
  21. dmar836
    dmar836
  22. HOTRODPRIMER
    HOTRODPRIMER
    As I heard when my most recent V6 thread got shut down, just because it falls under pre 64 doen't make it traditional! :rolleyes:HRP
    Tman and Hillbilly Werewolf like this.
  23. John Kraft
    John Kraft
    Body is on rotisery so going upside down to fit in car
  24. Johnboy34
    Johnboy34
    from Seattle,Wa
    How about a couple pictures of how you have the tudor body mounted on the rotisserie?
  25. John Kraft
    John Kraft
    Heres the front rear about the same just some 1 1/2" angle shaped to match two front bolts
    Tman and Johnboy34 like this.
  26. John Kraft
    John Kraft
  27. willys36
    willys36
    I did that for my '53 Chevy pickup king cab project. Had to cut the insert into 4 pieces to get it to fit. Made a 'gl*** center panel to cover the joint.
    Used the top as a form as John did.
    3 layers of mat is perfect.
    I welded 3/4" square tubing braces for the top extension, which served as headliner mounting brackets too.
    Funnest part of whole project was peeling off PVA mold release. I buy electronic stuff just to be able to peel off the protective films. It's a fetish.
    First cuts to shrink the exterior panel to interior size. Screwed the rough panels in place to allow accurate fitting.
    Final cuts, saded tapered edged of joints for 'gl*** patches. Also had to add some egde fillers to complete the form that the exterior pattern left out.
    I ***embled the whole thing into one piece to allow laying the center panel inside this main panel. I cut the center split after upholstering so everthing went together perfrctly.
    I joined the front and back pieces but had to leave the center joint. Could not get the full panel inside. This shows the shape of the center panel I laid in the main panel to cover the center split. Laying out the upholstery closed cell foam ready to cover with cloth.
    This is the center panel covered with Naugahyde, ready to install. I used hidden wire spring clips to snap this in place.
    Center panel mocked up on main panel while upholstering.
    the completed headliner set, ready to install.
    Final installation.
    drdave, GordonC, Cgrgrspt10 and 6 others like this.
  28. willys36
    willys36
    Big Father is about as traditional as it gets I reckon!!!!!!
    jaracer, Just Gary and indyjps like this.
  29. indyjps
    indyjps
    @willys36 Wow, that came out amazing. Lot of steps.
  30. Johnboy34
    Johnboy34
    from Seattle,Wa
    Thanks, I've been trying to decide on how to mount my tudor. Is that Raptor liner on the bottom?
