Projects Headliner one piece
Discussion in 'Traditional Hot Rods' started by John Kraft, May 23, 2022.
  1. John Kraft
    John Kraft
    Yes great stuff
    Johnboy34 likes this.
  2. alchemy
    alchemy
    I’ve been wondering about doing this, but with a steel skin in a smaller coupe. I probably wouldn’t have the curves on the edges, so some side upholstery panels. But I would do it so the tin panel could be painted, not upholstered.
    Are you guys putting any sound deadening material between the layers?
  3. John Kraft
    John Kraft
    Yes I have Lizard skin deadner and heat coatings
  4. John Kraft
    John Kraft
    Third layer is down now
    -Brent- likes this.
  5. Like I mentioned Cole Foster did his AD pickup in steel, he told me he would never do it again. There is a guy on our AD page making head liners out of molded ABS, I would go this route in a small coupe
  6. -Brent-
    -Brent-
    Awesome!
    I am planning on doing the same concept for my coupe's headliner. There are a few really great YouTube vids on surface prep and such.
  7. willys36
    willys36
    Prep for mine was a coat of single stage acrylic, couple coats of mold release wax and spray on PVA. Cured 'gl*** shell popped right off.
    green top.jpg Green top w- release.jpg Green top w- mat.jpg Green top in sun.jpg
    Just Gary, GordonC and -Brent- like this.
  8. John Kraft
    John Kraft
  9. stanlow69
    stanlow69
    I have done this in the past with the one-piece headlines found in newer style vehicles. Just trim it to fit.
    2deuces64 and -Brent- like this.
  10. John Kraft
    John Kraft
    Ok fitting split headliner only have to cut long ways
  11. goldmountain
    goldmountain
    Rotisserie for doing the headliner is a great idea.
    indyjps and -Brent- like this.
  12. Henry27T
    Henry27T
    Looks great, you cut the leading edge off to tuck it into that pocket, nice finish
  13. John Kraft
    John Kraft
    Going to be two piece fits alot better can tuck it in every where no need to attach locked in
    indyjps likes this.
  14. Roothawg
    Roothawg
    Pretty freaking cool
  15. Johnboy34
    Johnboy34
    from Seattle,Wa
    Turning out cool! I have another question about the center of gravity on the rotisserie, how far up from the bottom of the body is the pivot tube? It would be helpful to have a starting point for mounting mine. Thanks.
  16. John Kraft
    John Kraft
    Lizard skin sound control first coat going under headliner
    indyjps and Tman like this.
  17. John Kraft
    John Kraft
    Here it is with centerstrip bonded to both sides just need to install 1/4" foam on both sides to make it seamless
    drdave and Tman like this.
  18. indyjps
    indyjps
    As fun as fibergl*** is to work with :eek: I'm liking the abs plastic idea.
    How's it work? Line a flat sheet up, heat it, press into place with some supports and let it cure ? Would need to layout and transfer attachment points but that's not too bad.
    The sheet would need to be larger than the roof to flex up for shape and the pillars are likely in the way. There may be enough room to get it in 1 shot.
  19. Years ago (20+) our local interior hot shot did my bosses interior panels in ABS then they sprayed them in a smoothish bedliner for his A roadster. Turned out super cool and durable, you could just wipe em down..
    indyjps likes this.
  20. John Kraft
    John Kraft
    With 1/4" foam now to design
  21. VERY nice!
