heads up
Discussion in 'The Hokey Ass Message Board' started by the ratman, Apr 13, 2011.
  1. the ratman
    the ratman
    from illinois
    Hey gang . So Im in the process of checkin out some finned aluminum offy heads for my 8ba flat motor but these are pre 49 style heads so what do I need to do to make these work on My motor? I seem to remember something about blocking water passage holes thanks. Dave
  2. flatoz
    flatoz
    yes one hole each side, its about 3/8th's in diameter being it hasn't rusted larger. once you put your heads on your block you will see which one it is as the heads will partially cover it. just tap it and put a allen head screw or as we call them grub screw in it with loctite.
    I'm sure if you do a search it will come up. and someone will have photos.
  3. the ratman
    the ratman
    from illinois
    thanks fer the help
