Technical Heat blocking gel or putty
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Mar 3, 2026 at 3:17 PM.
  1. seb fontana
    seb fontana
    from ct
    In the future I will have the need to bend some F1 front frame shock mounts. Can't remove one bolt so will need to heat and bend in place, making little bit of "S" shape. A bout 5° or so. What is the latest and greatest heat blocking gel or putty?
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    Don't know if it's the latest and greatest as I've had it for awhile, but Goss Heat Barrier putty has worked good for me. I like that it can be reused also.
  3. seb fontana
    seb fontana
    from ct
    Thank you. My initial search on amazon for spray heat blocker was for hair! So I went to proper source!!
  4. BJR
    BJR
    Why can't you remove one bolt? Got a picture?
  5. seb fontana
    seb fontana
    from ct
    No pic but will try to explain. Rectangular tube frame, about 2 ft from the end. Can see with a bore scope but can't get arm in with a wrench will loose bores cope.! We get a little warmth in weather and I'll get my friend over with his cell phone that can take a borscope pic..
