Technical Heat Sheild Material and Brake lines
Discussion in 'The Hokey Ass Message Board' started by swade41, Aug 15, 2023.
  1. swade41
    swade41
    from Buffalo,NY
    I'm going to make some type of heat shield for my brake lines, bolt it to the lower two bolts under the master cylinder, to help the foreseen issue.
    My thoughts are to loop tight under master, back to inside firewall recess, then down, seems the "coolest" routing option.
    I have aluminum and stainless, stainless is thicker than the aluminum, which is better for the intended purpose ?
  2. In_The_Pink
    In_The_Pink
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    All the OE stuff is aluminum.
    Sharpone likes this.
  4. Bandit Billy
    Bandit Billy
    If it were me I would run those lines up and over to the firewall as fast as possible rather than any where near those headers and throw in a couple of loops that would be right along side the M/C. See technical drawing #1.
    I would likely build the heat shield from aluminum (shiny on the outside) and use a phenolic layer inside (for heat protection). Go around the bottom and up the left side protecting and hiding the loops. See tech drawing #2
  5. Jim Bouchard
    Jim Bouchard
    I agree with Bandit Billy on the placement
    Aluminum for sure
    You could also build two identical panels and bolt them together with 1/4” spacers in between to give extra heat distribution and protection with the second panel.
    Or, a master cylinder with the ports on the other side and run them down the tunnel avoiding the headers all together.
  6. Both great ideas
    Jim Bouchard likes this.
  7. blue 49
    blue 49
    from Iowa
    I have a little tab of stainless between my # 1 header tube and my alternator. Seems to do it's job.
    Gary
  8. pvfjr
    pvfjr
    For designing a heat shield, it is not thermal conductivity you're looking for. What you want is low emissivity, since you're trying to block radiative heat transfer. Here's a nice chart:
    https://www.engineeringtoolbox.com/emissivity-coefficients-d_447.html
    Polished aluminum has one of the lowest numbers out there. Bear in mind, once it's dirty or oxidized its effectiveness is greatly reduced.
  9. The commercial stuff the go-fast boys put around their turbos is a woven sandwich type aluminium sheet, it can be worked and bent just like ordinary sheetmetal, and is very thin.
    alanp561, VANDENPLAS and loudbang like this.
  10. BJR
    BJR
    heat shield mounted.jpg Here is what I did to cool off my new dual master cylinder on my 56 Thunderbird.
    alanp561, chevy57dude and winr like this.
  11. Just Gary
    Just Gary
    Why not just slice some 3/8" rubber hose lengthwise and cover the brake line closest to the exhaust with it? o_O
    Zip ties can hold it in place if needed.
    Rubber is a far better insulator (lower thermal conductivity) than aluminum or stainless steel.
    chevy57dude and Tman like this.
  12. TerrytheK
    TerrytheK
    Another option - I got some stuff from Summit Racing that's an insulated sleeve made to fit over tubing or wiring. Not sure who makes it or what it's called - heat sleeve maybe? Comes in several sizes and lengths. I used it on transmission cooler lines. Might do the trick if you use it on the brake lines.
  13. blue 49
    blue 49
    from Iowa
    ^^^^^ I used this where my fuel line runs by the exhaust from my rams horn manifold on my '36.
    Gary
    Tman and Just Gary like this.
  14. swade41
    swade41
    from Buffalo,NY
    My headers are really tight to the firewall so there's only a couple of spots to feed in there.
    I mocked up a couple different routes, the loop under the master and over to the recess didn't look the greatest and is pretty close to the borgeson joint on the steeringshaft, this is the other which looks better.
    The trade off is the lines within a couple inches of one tube or under the master absorbing heat off all the tubes.
    I do have some of that heat shield from DEI I think that I could put around the lines but I think it'll need something in addition to it.
    chevy57dude and Bandit Billy like this.
  15. seb fontana
    seb fontana
    from ct
    I understand what the OP is thinking but the MC is still out there absorbing what it can. The loops in pic would make for some interesting brake bleeding. If that concerned run the lines behind the firewall in between typical interior insulation.
    mohr hp and 2OLD2FAST like this.
  16. Ned Ludd
    Ned Ludd
    You beat me to it. Polished stainless is close, and should hold its shine for much longer.
    Blues4U and pvfjr like this.
  17. chevy57dude
    chevy57dude
    Your headers look like mine. I whipped up an aluminum shield and put heat blanket on the underside. No issues.
  18. SS327
    SS327
    Asbestos still works the best!
  19. 1971BB427
    1971BB427
    from Oregon
    I personally avoid running any lines higher than the outlets on the master as it can often make bleeding the system troublesome. I would indeed get the lines pointed back to the firewall directly, just not up higher first.
    I always use aluminum as it shields as well as anything, but dissipates heat faster.
    seb fontana, loudbang and 2OLD2FAST like this.
  20. I would make a double walled heat shield for the master (with about 1/2" space between the sheets of 3/16" aluminum), then run the lines into the inside the firewall wrapped in the DEI heat sheath and pop back out at the bottom of the firewall (routing them to the left side away from your feet as much as possible.
    pvfjr and y'sguy like this.
  21. RmK57
    RmK57
    I would start the engine, get it good and hot, then check with an infrared heat gun, the engine compartment looks well ventilated.You may not need anything. Looks like a good 4-5” from the m/c. Route the brake lines above the old master bottom bolts.
    Blues4U likes this.
  22. '29 Gizmo
    '29 Gizmo
    from UK
    I don't think the brake lines or master cylinder are going to be an issue as brake fluid is stable at temps way beyond anything you will get that far from the headers.
    Having said that the issue could be firewall behind the headers. That will get hot from the radiated heat off the headers. I would seriously consider using stick on gold heat reflective material to stop the heat getting in the cab.
  23. bobss396
    bobss396
    You can even rest a beer on it... win... win...:cool:
    chevy57dude, swade41 and KevKo like this.
  24. rattlecanrods
    rattlecanrods
    The asbestos panels on the firewall of the Healey I worked on site did the trick. Wouldn't hesitate to use them again.
  25. swade41
    swade41
    from Buffalo,NY
    So this is how I routed them and I think I'll use the stainless as the shield and bolt the proportioning valve to it.
    20230821_165026.jpg 20230821_165046.jpg 20230821_165100.jpg 20230821_170714.jpg
  26. Bandit Billy
    Bandit Billy
  27. Looks great! The coated headers should be enough to keep the heat away... makes a big difference
  28. earlymopar
    earlymopar
  29. 54chevkiwi
    54chevkiwi
    For anyone reading this in the future, use the highest dry boiling point brake fluid that you can. Wilwood 660, torque rt700, Castrol etc. it's expensive but we care about it old cars right?
    Don't use any of that $10 Valvoline ****.
  30. Kerrynzl
    Kerrynzl
    Cut your hard lines along the frame rail somewhere , and use a joiner.
    Get some [one] braided brake hose made with a banjo fitting at one end [and banjo bolt into the M/C]
    Run the brake line down the firewall with the banjo orientated rearward.
    Fasten to the firewall with Cushion "P" clamps
    Join the other end to the hard line.
    I've seen this method used on numerous race cars.
    It also allows for removal of the M/C from the firewall without needing to bleed afterwards
    rattlecanrods likes this.
