Technical Heater Box Id ?
Discussion in 'The Hokey Ass Message Board' started by BigRRR, Dec 28, 2025.
  1. BigRRR
    BigRRR
    I have this heater box that I am trying to identify… the box it was packed in was marked ‘48 Ford … this doesn’t seem to match! The blower motor is a newer replacement, but the box looks to be vintage!
    It’s approximately 12x9x6”. IMG_3338.jpeg IMG_3339.jpeg IMG_3340.jpeg IMG_3341.jpeg IMG_3342.jpeg IMG_3337.jpeg
    Anyone have any thoughts on its original origins???
  2. 302GMC
    302GMC
    from Idaho
    Commercial - bus or off road truck ....
    49ratfink, Joe Blow and squirrel like this.
  3. squirrel
    It could have been installed in a 48 Ford...but not by Ford....
  4. BigRRR
    BigRRR
    It was in my dad’s garage and he had a 48 Tudor. Not sure if it was out of his 48 or if he had picked it up at a swap meet to install, but does not look like any of the Ford heaters that come up in the search engines
  5. squirrel
    It's not a Ford heater, it's an aftermarket one for "industrial" applications.
    I would put it in something besides a 48 Ford! or sell it on ebay
  6. BigRRR
    BigRRR
    Yep, agree! Thanks
  7. leon bee
    leon bee
    Like a combine cab, something like that.
    vtx1800 likes this.
  8. gene-koning
    gene-koning
    With about a 10" x 6" heater core, if you could keep the coolant hot enough, it would be a great heater. The round holes in picture #3 would be where the tubes to connect the duct work for defrosters would be located, but for the defroster to be very efficient, there should be doors to close off most of the other vents. With out the tubes for the defroster ducts, and without closable doors over the other vent openings, this unit was specifically built for heat only.
  9. BigRRR
    BigRRR
    The heater core is 10x4x2.5” and I do have the duct plate for defroster tubes and a cable operated door to control defrost/heat modes.
    I was considering it for an under dash unit for a 50 Merc to mostly feed the defrosters.
    Tim likes this.
