I've planned painting(or maybe a powdercoating?) my shoebox projects heater box.The factory paint has chipped off from here and there and there is some surface rust on the box too.So it really needs something. I've heard that some paints will cause fumes on the spots like heater boxes etc,so it could be pretty lame to get a horrible headache everytime i use the car. Any suggestions what to use?
I've not noticed it to be a problem. The heater box gets warm, which helps the paint finish curing, so it won't give off fumes. I've only used spray cans to paint heaters, and not had a problem.
I've painted several heater boxes in the past,I especially like the wrinkle finish and you only smell the curing of the paint the first couple of uses,not strong. HRP
Heater box (on the inside of the car) is only going to get about as hot as the water flowing through the heater core. You're over-thinking it. Paint it.
Thank you all for the answers! That hammertone might be the one i've been looking for.I am not much of a restorer,but it looks like that the box is coated originally with that kind of stuff.I also have a small cashbox,which is going to be a fusebox.I guess i'll paint that too with the same stuff:
That cash box is giving me ideas on firewall/trunk mounted component boxes- might have to raid the wife's garage sale supplies....-rick
You can add to the fun ... stick wet but flashed off parts in your oven with a 130-140 degree temp. for 20 minutes. Most guy's wives will understand ...
If you can find an old junk stove you can make your own drying oven. You could put it in the garage and plug it into 110Volt. It won't get as hot as 220 but hot enough to cure paint. Of course if you have 220 in the garage you could use it for powder coating too.
That was pretty cheap way to hide modern looking fusepanel,that didnt cost a dime to me.I welded a bung on the latch side,made a stainless steel handle and added some mounting tabs to the back side. Here is an another pic of the box closed: Well,thanks for the oven suggestions too.That oven might be handy in some other projects too..
