heater control
Discussion in 'The Hokey Ass Message Board' started by unkamort, Oct 21, 2010.
  1. unkamort
    unkamort
    thinking a bit down the road... I'd like to find a heater valve control cable that will also turn on the fan. Both functions with one knob. Anyone know of such a thing is available? Examples?
  2. tanof
    tanof
    from New Mexico
    You might not want that. At max temp, would you always want full blow?
  3. KrisKustomPaint
    KrisKustomPaint
    You could find a knob that had pull and twist, speed on the twist and pull for the valve.
  4. unkamort
    unkamort
    Yeah.. thats what I had in mind> I know I'v seen these, just can't place where
  5. tanof
    tanof
    from New Mexico
    Use a headlight/dimmer control. The dimmer controls the flow of water to the heater via an electric valve control. The headlight provides two or three fan speeds. You can also reverse it to get infinite fan speed control.
  6. 1966 c-10 chevy pick -up.3 speeds with a cable for the valve.although on the truck the cable goes to a blend door.
  7. Dennis D
    Dennis D
    63-67 Corvette. Don't know if they are repopping these or not. Last one I bought I had to get for an AC car as that is all that GM had left.
  8. junkyardjeff
    junkyardjeff
    I think my 66 f250 has a switch like that for the heater,pull it out for the temp and twist it for the heater motor. You will still need a control vavve at the other end of the cable to control the coolant flow through the core.
  9. lstwsh
    lstwsh
    from Dayton,Oh
    Vintage Air sells the cable you are looking for.You pull the cable for heat and turn the knob for fan speeds.They also sell the valve separate too.
  10. belyea_david
    belyea_david
    from Regina, SK
    1976 Dodge Vans have a switch/valve control that you want.
  11. 2x4
    2x4
    Funny, I was just looking for one this AM.
    Here's what I'm looking at from Vintage Air, they're about $90 on the street.
  12. unkamort
    unkamort
    Thanks to all... i'll put this on the growing bone yard run list.
