Technical Heater Core: How to remove Pine Needles in Fins
Discussion in 'The Hokey Ass Message Board' started by MrCreosote, Dec 22, 2024.
  1. MrCreosote
    MrCreosote
    from USA
    They're stuck all the way in. Every light spec in the pic is a needle completely in the fins.
    Compressed air and vacuum did hardly anything.
    Think of way to dissolve they or reduce to ash.
    • bake in oven
    • caustic soak (hot tank)
    • Soak in flammable liquid, fill core with water, set on fire.
    Radiator shops probably have a way to do (if you can still find one.)
  2. choptop40
    choptop40
    pressure wash with low pressure spray nozzle from the back holding tip straight fanning left to right...
  3. In_The_Pink
    In_The_Pink
    Tweezers first, then hot water blast with a nozzle on a garden hose. Poke between each fin as necessary with a dull object like the tang end of a points file.
    borntoloze, Just Gary and SS327 like this.
  4. DDDenny
  5. Mr48chev
    That is how I would do it, I've done a **** ton of them at the car wash when I washed the engine off.
    When you have it clean I'd put a piece of loose weave window screen in front of the radiator. My grandfather and a lot of others did that on their cars to keep the bugs out of the radiator around here as it was a lot easier to clean the screen than the radiator.
    brading likes this.
  6. brading
    brading
    Cut the pointed end off of a cable tie and push that through.
    jaracer likes this.
  7. Slow down
    Slow down
    Gentle washing in the wife’s laundry tub when she’s not home.
  8. I wonder if the stuff the home HVAC folks use to clean the condenser with will do the job?
    Ben
  9. arse_sidewards
    arse_sidewards
    from Central MA
    Green tip on pressure washer. Shouldn't take long at all.
    The problem with plant matter is that it's mostly cellulose is that not much dissolves it except other organic processes eating it so your chemical options are gonna be limited.
  10. BJR
    BJR
    I would try to soak the core in water overnight to soften the ****, and then try compressed air. Be careful with a pressure washer, I have bent the fins on an air conditioner with one before.
    Just Gary likes this.
  11. reagen
    reagen
  12. jimmy six
    jimmy six
    Excuse me for asking …. But how did the pine needles get to the heater core?
  13. Soak it to soften the needles, then pressure wash it.
  14. HOTRODPRIMER
    HOTRODPRIMER
    Take it to a old school radiator shop (one that works on radiators instead of replacing them with a new aluminum radiator) and have it vatted, that stuff will remove any **** in the tank and the pine needles. HRP
  15. garyf
    garyf
    They fall down the cowl vent. I would use a cut to fit black window screen under the factory (usually plastic grill) on my cars to prevent this.I found, Almost all the cars with leaking a/c evaporator cores were sitting in a bed of pine needles once the case is opened.I think the acid in pine needles eats away at cores.
    jimmy six and arse_sidewards like this.
  16. Put me on the "I'd use pointy tweezers" list please :)
