Technical Heater core repair
Discussion in 'The Hokey Ass Message Board' started by Gremlinguy, Aug 25, 2019.
  1. Gremlinguy
    Gremlinguy
    The heater Core on my 63 Rambler American is in need of repair. Cant find a new one, and the AMC vendors arent much help for my year.
    Does anyone have a shop they recommend I can send mine to and have it repaired?
  2. mgtstumpy
    mgtstumpy
  3. Some radiator shops can repair them, I've had several fixed locally by one.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Do you have a old school radiator shop where you live, the real repair shops can usually repair a core. HRP
  5. Gremlinguy
    Gremlinguy
    I havent been able to find any close by.
  6. brigrat
    brigrat
    from Wa.St.
    Br*** Works...................................................
    https://www.thebr***works.net/heater-cores.html
    Heater corer's usually don't spring a leak in the core like a radiator but the top and bottom tanks can separate and leak. Most shops will just order or cut a core, clean tanks and solder back together............................
    Gremlinguy likes this.
  7. Some heater cores are easily modified to fit a new application. A hole saw, some pennies to block off old holes, and some copper tube for odd bends, and a big-***ed soldering iron.
    Truck64, irishsteve and little red 50 like this.
  8. 51504bat
    51504bat
    If you can't find a local shop, these guys can do it and they ship. I've had them repair a radiator in a '40 ford big truck and also modify a '39 Ford p/u radiator. Quality work, fair prices IMO.
    http://fontanaradiator.net/
    Gremlinguy and Blues4U like this.
  9. Blues4U
    Blues4U
    from So Cal
    Thanks for the link.
  10. farna
    farna
    Best bet is to go through a catalog and find something of similar size. I know a couple of the AMC guys have swapped in other cores -- that one is pretty easy to do due to heater location -- but I don't recall what they used. Easy to mod where the inlet/outlet is -- as long as you don't mind drilling the fibergl*** cover.
