Heater core replacement (63 Riviera)
Discussion in 'The Hokey Ass Message Board' started by Painter D, Dec 20, 2009.
  1. Painter D
    Painter D
    from DFW
    I searched.
    When you replace the heater core on a 63 Riv. do you have to pull the whole center console out? Just part of the dash out? ,or can you access it through the firewall?
    I'm sure I'll figure it out either way, I'm just lookin for a little help.
  2. speedcity
    speedcity
    You can't get it from the outside and I am pretty certain that you will be removing the console. I hear it's a 6 hour job. Sorry.
  3. Eagletucky
    Eagletucky
    I did this about 4 years ago. Speedcity is right. Its from the inside.
    BTW, this job sucks donkey dongs!
    Take your time, it should go fine, just time consuming and make sure you stretch out before you start.
    Good luck.
  4. ESnacky6
    ESnacky6
    Wow. I guess I'll chime in here as well.... :cool:
    as said, this job DOES suck donkey dongs..!! huge pain in the ass....
    you do have to remove the center console, the AC under the dash
    if you have it (we removed ALL of the stock AC since it didn't work
    anyway, and made it easier to put back together)....
    You also do need to access it from the engine side, for the hoses
    etc.... It took a friend of mine and myself 8-10 hours to complete,
    mostly because there was one damn nut on the engine side we
    apparently missed (under some insulation) that kept us from removing
    a panel or air duct of some sort.... (this was 5 years ago..? sorry
    if I'm not 100% accurate) I remember talking to other guys about
    it and one saying stuck in my head: in the 60's, it seems like GM
    started with the heater core and built the car around it..!! :rolleyes:
    Just keep track of what goes where, take pictures if you have to,
    and if you can, get a hold of a service manual.... it will help you
    with a LOT of various repairs, replacements, etc. on your car..!!
    Good luck..!!! -Snacks....
  5. ESnacky6
    ESnacky6
    p.s.- This will be a good time to replace/rewire anything in your
    console that may need it.... I replaced both cigarette lighters,
    all bulbs, AND the plastic lens for the light for the rear seat area....
    I can't remember if the '63-'64 had that light as well, but my '65
    does.... (most of those lenses are cracked or missing from it being
    impossible to access without removing the whole damn console)
    I also ditched the factory heating ducts in the console that were
    falling apart anyways.... i guess you could make new ones, or
    fiberglass over the old ones, but my 425 puts out enough heat
    that I'm fine without....
    If I remember anything else I'll post again....
  6. ESnacky6
    ESnacky6
  7. 302GMC
    302GMC
    from Idaho
    It's all true, flat rate for core R&R was 6+ hours. The one I did had the core repaired & leaked after putting it all back together.
  8. Painter D
    Painter D
    from DFW
    Thanks for all the help guys , guess I'll start gearing up for the job.
  9. Painter D
    Painter D
    from DFW
    The new heater core "FINALLY" showed up today so I'll be starting on it soon.
    I have another question though: Can you bypass the "water flow control valve" or do you have to hook up the hoses to it so the water will flow through it and the core?
    Does anybody have a diagram or pic of how the hoses hook up to the core and the water flow control valve? I'm assuming you have to have the WFCV hooked up for it to work right.
  10. Painter D
    Painter D
    from DFW
  11. ESnacky6
    ESnacky6
    Just take pics and write stuff down before you tear it all apart..! :cool:
    I remember we did bypass it for a while, but that means water
    is constantly flowing thru, therefore somewhat heating your car....
    I now have a manual water flow control valve since we tore out
    all of the stock AC crap that didn't work, and all of the vacuum
    lines for the controls in the console....
    My fan switch works, but for heat I have to 'turn it on' manually....
    make sense..?
    other than that, I would strongly recommend getting a factory
    service manual..! you can find copies on ebay or at car parts
    swap meets.... it's the thickness of a decent size phone book,
    but it has been a very valuable investment when it comes to
    tasks like changing the heater core..! good diagrams, pictures etc....
    Rock on..!!
  12. Painter D
    Painter D
    from DFW
    THANKS for the help. I forgot to mention the reason I could use a pic or a diagram is because none of the hoses to or from the core ,or the WFCV are in place.
