Projects Heaters.........who has em...are they just for sissys??
Discussion in 'The Hokey Ass Message Board' started by cruzr, Feb 8, 2009.
  1. langy
    langy
    I'm in the U.K. so i like heaters.
    Here's mine
    Here's the wifes
    This one is for my 26T
    I must be a right sissy as i have heated seats as well :D
  2. lostforawhile
    lostforawhile
    yea i just can't figure out the i'm too cool for a heater thing. and as far as out there in southern cali, I have friends there and it can get dam cold sometimes, I still know people that think it never gets cold down here in the south eithier,yea come on down in your shorts and sandals when it's 25 degrees in the morning, we neeeever get cold here :D
  3. metalmike13
    metalmike13
    from Glass City
    i've got one in my olds, never plumbed it up though. It would be nice for fall cruising. Lately it doesn't snow here until begining of DEC.
  4. H3O
    H3O
    i'd rather have a heater than a/c. needed that when the wind chill gat to be -12. if i didn't, that would've definitely ****ed.
  5. I've driven my 1992 daily driver for several years without a heater since the core got a hole in it and I'm not about to go to all the trouble to drop the steering column, pull out wiring, remove the whole dash unit and then the other "cover" behind it to get at the core:eek:. Time is limited working two jobs and I'll spend my car time on my '53.
    The biggest problem I've found is the lack of a defroster when driving in wet weather, a rag just doesn't cut it:mad:. That's why I think a heater WITH defroster ducts is a good thing.:D
  6. crackernutz
    crackernutz
    from tx
    where are you guys getting thove art deco heaters from those are soo cool
  7. oilslinger53
    oilslinger53
    from covina CA
    Pshhh... nothing wrong with being warm! besides, it's good to have in case, for some reason your car starts overheating.
  8. 53choptop
    53choptop
    This is an unbelievable idea HP. Thank you, Thank you, Thank you. This is exactly the idea I was looking for for the 37 ford truck under seat gas tank I have for the wifes 36 were working on. We are not using the tank for gas, but was looking to see what we could use the tank space for. This is definitely a "print and save" tech thread!!
  9. I live in Minnesota so it's almost a necessity. I drive my rod well into winter until it starts to snow. Used to ride motorcycles in the winter(22degrees) when I lived in Wichita. That's when I was young and tuff or dumb.
  10. paintcan54
    paintcan54
    I live in the snow and rust belt, have heaters in two of my rides, and thinking of a heated seat in my open bucket, getting to old to ride in the cold, the wife says wear more clothes but you can only put on so much.
  11. screwball
    screwball
    defroster heater is law in Ontairo no defrost no driving. Simple as that unless you get a fake saftey then its just another rat rod if you dont keep to the law.
  12. Boyd Who
    Boyd Who
    No heater in my Es*** now, but when I re-do the truck it will be getting one. I like to be warm when I drive.
  13. 32gal
    32gal
    from The OC
    How are you guys hooking up the heater?? what control are you using to shut water off to heater when not in use so it doent run hot air all the time?
  14. lostforawhile
    lostforawhile
    there's one on most old hondas,can get it at almost any junkyard, it's a simple lever valve,in and out, will hook up to a cable eye. i haven't seen one fail yet. can probably pick one up for a buck or two. then maby a manual choke cable or something like it. i saw a nice one at the car show here, was all br***s.
  15. Hoovs42
    Hoovs42
    from So Cal
    You don't have to cover for the old man....I know the real reason he sold the bucket was because he can't take the cold anymore. :rolleyes:
  16. I'd rather be warm than cold, I'll be installing a heater in my car.
  17. Mr48chev
    Count me a**** the bunch who like our comforts and plan to have heat and ac in the truck this time and that little aftermarket heater that I have had stashed away for the past 25 years in the roadster.
    I've spent too many summers broiling in the chopped cab of my truck with limited airflow because of the chop. I've also spent too many winters freezing my *** off in the same truck because the heater didn't work.
    The heater for the roadster increases the range and the amount of time that I will be able to drive it without a snowmobile suit. To get to any gathering of PNW HAMB folks I have to go over a mountain p*** or a close resemblence. It gets cold up there at night or early in the morning. Sunrise on Chinook p*** is a beautiful experience to witness but even in the middle of July it is in the low 30's at 6 am up there.
    A heater will help increase the range you can travel comfortably with the car and as mentioned above it helps keep the female companions happy unless you just don't care to have female companions along for one reason or another. If your lady is cold it is going to be a long miserable night usually.
  18. rustrustler
    rustrustler
    If you have to be cold to be cool, I'm not. Mike
  19. Django
    Django
    from Chicago
  20. hotrod1940
    hotrod1940
    I love the Art deco heaters, and I love the warm. Only sissies use the word sissies. Manly men know how to hook up a heater and turn on the switch.
  21. 32gal
    32gal
    from The OC
    Ok i guess the consenus is heaters are a good thing! I am looking forward to having mine installed in my new Roadster and being cozy warm .
  22. Doc Squat
    Doc Squat
    from tulsa, ok
    I had a Vintage A/C and heater in my 56 F-100. I've also put same in my deuce. I grew up in Iowa and was cold all my life. Fu*k that **** I want to be comfortable. If the truth is known I use my heater more than I ever will the A/C. I can always get in the shade and have a Pepsi to cool off, not so trying to get warm. Just my opinion.
    ______________________________________________________________________
    Like I told the kid, "Your music's not too loud, it just ****s and so does OKC!"
  23. Large_911
    Large_911
    See my signature...lol
    But seriously, if I was going to drive my car everyday in the winter I would run one. I just removed it for clutter & weight reasons.
  24. Crusty Nut
    Crusty Nut
  25. gas pumper
    gas pumper
    I've used `1/2 inch pipe ball valves to shut the water off at the engine to keep the hot water out of the coil in the summer. Really only one valve is needed on the supply side, but two will let you isolate it in case the core or hoses start leaking.
    On one car i used the gas shut off valves (like at a stove), same as a ball valve with smaller handles. Regular hardware store items.
    Vintage valves are all br*** and don't look modern.
  26. R A Wrench
    R A Wrench
    from Denver, Co
    For heater controls I have used a valve for a full sized Dodge van from the early 80's. They mount on the hose, inline with a cable operated valve. They are small and easy to install, no mount brackets, neat appearance, and CHEAP.
  27. Dr.Kerry
    Dr.Kerry
    when I build my 30 it'll have one.
  28. kruzr
    kruzr
    This might sound dumb to some.Worked for me.
    The 34 p.u. I built years ago,gone now darn. Being a smaller area(cab) to take the chill off,I incorporated a ****** cooler in right side kick panel,used adapters from block to run small hoses cause heater hoses are ugly to me.Ran the 1/2 inch lines along the frame up thru the bottom of cab,made a small cap for top of the t/cooler with a fan and ball valve to control the flow.Never did finish the defroster hook up.
  29. cruzr
    cruzr
    now i need one for the 31 coupe , similar to this one, anyone have one out there??pm me
  30. man that must be a sight driving around the woods compound, keeping your eyes peeled for golf carts :D.
    all my cars have them, if not for heat for defrost. too much work wiping windows and trying to drive on the freeway to work in the early am.
