Heaters?
Discussion in 'The Hokey Ass Message Board' started by nlualum82, Jan 29, 2011.
  1. nlualum82
    nlualum82
    from Oregon
    I need to find a small, cheap, simple means of heating my little primer gray '36 Chevy pickup.
    I have only begun to look at aftermarket units and they are mostly too large and/or expensive.
    I have never been in the market for one so I haven't been looking under dashes in junkyards yet.
    Any help?
  2. Blue One
    Blue One
    from Alberta
    Search heater under auto parts on e-bay plenty of the small vintage heaters for sale.
  3. Mid 50's GM products had under seat heating. Round heater core and blower motor all mounted up under the seats.
  4. 56oldsDarrin
    56oldsDarrin
    early 70s ford pick up heaters will cut down pretty easily,they are still ugly, but they have a cheap heater core, and ducts for defrosters.
    Big old farm trucks have really cool (and attractive) little heaters, also usually with defroster ducts, but you may have to do a little rigging to replace the core.
    If it shows I would go the big truck route.
  5. RichG
    RichG
    Take a heater core, a couple computer fans, some hardware, and a bit of steel, and make your own!
  6. I though this was about old women?
  7. The old Ford Courier (Mazda) pickups from the '70s had a very compact little heater that could be adapted to just about anything, as do some of the older postal service Jeeps. As others have mentioned, the universal aftermarket heaters made from the '30s to early '50s are cheap and plentiful. I have a '30s vintage Hot Wave brand heater in my '38 Ford pickup that works great. If you need to replace the core in one of these old heaters (usually they are good), just find something roughly the same dimensions that will fit in the case and has the outlets in the right place. The NAPA guy, eBay, or junkyard scrounging will find you a 12V motor to replace the 6V, or you can use a voltage reducer to drop it to 6V if the old blower motor is good. I adapted a blower motor from a late '60s or early '70s Dodge pickup to my heater.
  8. they make little 12v electric heaters and sell em at walmart.. one could mount a few under the seat.. alot easier to run some wires then it would be to run hoses and other doo-dads then just put a little switch to turn em on in the dash or where ever you'd like.
  9. I just picked up a Southwind heater from Espay for about $10- keep your eye out and you'll probably find one too. Now to get some modern innerds (they were originally run with fuel)!
  10. 1971BB427
    1971BB427
    from Oregon
  11. T Achilli
    T Achilli
    from walworth
    RichG............ I like the idea with a different type of fan than a standard squirrelcage Computor fans might be a touch small and i am not sure but i think they would need a 110 converter.........along the same line, a lot of Hot tubs come with a slim line fan 3 to 4 inches in a square frame that could be adapted easily but once again I believe they would need a 110 converter.
  12. kustomsrule
    kustomsrule
    from L A
    Don't know what your budget is but I'd look into getting an original type gasoline heater. There's a guy in Canada who sells completely restored, guaranteed functional units by South Wind. They cost about $200 - $250, depending on the model. There were over three million units made by South Wind for cars of the '30s, '40s and '50s. Look for him under southwindheater.com.
    I'm deciding if I want to put one of these in my '62 Rampside pickup and whether I want to to deal with a rheostat to change from 6 volt to 12. I'll probably do it.
  13. 4 pedals
    4 pedals
    from Nor Cal
    I bought one years ago from mr40sfatstuff for my 64. Very basic, core and fan, pretty cheap at the time. Just installed it recently, haven't wired the fan, so it's useless. I was looking at them from Jeep sites recently, much bigger, with ducting available to hook to defrost. Probably the way I'd go now if I were to start over.
    Devin
  14. Da Tinman
    Da Tinman
    computer fans are 12 volt, a little lite on the cfm but perfectly quiet and more than adequate for a small cabin.
  15. rustdodger
    rustdodger
    I don't know what you define as cheap but you might look into heaters for boats they make some pretty compact ones. I used to buy from a company called Heatercraft that as I recall was near Spokane. Another that I recall was called Red Dot maybe near Seattle. I would expect you would be near or over $200 for the marine stuff.
  16. shoveled71
    shoveled71
    I bought a small electric heater that plugs into the lighter a Harbor Freight for about 10.00, aint much but its all I need in Florida...
  17. RichG
    RichG
    Yep, and they're also the fans that are used on electrical equipment enclosures and AC VFD drives... as far as CFM, you can get them up to 500 CFM! That should make your hula girl dance!
    http://www.mcmaster.com/#equipment-cooling-fans/=at7hgj
  18. Da Tinman
    Da Tinman
  19. Never2low
    Never2low
    I used to run the same 4" fans for the opposite reason. (Cooling car audio amps.) They don't draw much from the electrical system. They are whisper quite. And if you run 2 or 3 of the 4 inchers you get more than enough air flow to heat a pick-up cab. Pick up a cheap heater core and fab a sheet metal manifold. BAM! Under a hundred bucks.
  20. chevy57dude
    chevy57dude
    Summit has a self contained heater - Mojave Flex a lite 640 for $200. All brand new stuff, ready to go. Kinda pricey, but it looks to be able to heat a vehicle (12,000 BTU). I tried a little electric one a long time ago, forget it! In order to make that kind of heat, you would need 3 alternators!
  21. 1/2done
    1/2done
    from Ohio
    I'm going to put an old under dash heater in my coupe. I already have one but there's tons on epay.
    Don't bother with the cigarette lighter jobs, you could fart and warm the cab up faster.
  22. old lady's mad
    old lady's mad
  23. '46/'47 Ford trucks have a nice little heater that works great and looks perfect..........other years might have that same heater.
  24. wingedexpress
    wingedexpress
    Make your own.I just finished one for my model a .I took 1/2"copper line and wrapped it around a 4" pipe to make the coil and used a motorcycle fan.Whole heater is only 6"x6"x6".
  25. matts37chev
    matts37chev
  26. I'm pre-declining a ride with you. Please don't take it personally...
    Cosmo
  27. spoons
    spoons
    from ohio
    we run the small, electric, plug-in style on the cars around here.....
  28. Da Tinman
    Da Tinman
    those were also used in 49 ford cars, the problem with those is that they are 15" deep, the motor and fan hang way out.
    search for "make your momma happy" and see my heater tech using one of em for a core.
  29. RichG
    RichG
    See? I don't have an original idea in my head, but they are some good ones! :D
