HEI gremlin help needed
Discussion in 'Off Topic Hot Rods & Customs' started by XXL__, May 11, 2024.
  1. chicken
    chicken
    from Kansas
    It's pretty obvious you know what you're doing. Maybe take along an extra distributor to get you home in case it fails again. Not a fix, but would save you from your health issues maybe.
  2. deathrowdave
    deathrowdave
    from NKy
    Run a straight 12 v power wire to it , see if the issue changes . Check for tight battery terminals and good clean grounds
  3. rockable
    rockable
    No, you addressed DC current. Set your meter on AC and see what ou get. It should be near zero.
  4. TA DAD
    TA DAD
    from NC
    So have you replaced the pick up ?
  5. enjenjo
    enjenjo
    from swanton oh
    I have had issues with the pickup causing modules to fail. It's been some time since I worked on an HEI but as I recall the resistance in the pickup was high causing the problem. An older professional edition Motors manual has the procedure for testing the pickup.
  6. TA DAD
    TA DAD
    from NC
    I guess he has broke down somewhere.
