HEI maintenance/ vaccum adv? help
Discussion in 'The Hokey Ass Message Board' started by larry woods, Mar 31, 2012.
  1. larry woods
    larry woods
    from venice fl
    I am running an HEI after market in my 327. Starting to develop a hesitation when i jump on it. the hes***ation isn't immediate but seems to start and then hesitate. I have checked vac*** hose and connections. seems like advance is late kicking in? Carb is Edelbrock 1406. suggestions as to what else to check? as usual thanx for your input. larry
  2. FiddyFour
    FiddyFour
    GMC BUBBA is the guy you want to talk to... he's the ignition MASTER
  3. jasper30
    jasper30
    from kansas
    Well you may need to check it with a timing light withba digital advance to see when its coming in. It could need a lighter spring kit. Also I've had trouble with the 1406 carbs and have had to purchase a metering rod/ tune up kit for them and play with them also. Good luck hope this helps
  4. GMC BUBBA
    GMC BUBBA
    First of all just unhook the vac unit and see if the problem is still there ...We are ***uming that it did run perfect for a while ????????
  5. larry woods
    larry woods
    from venice fl
    Yes, it had been running fine. will undo the hose to check. will post result, thanx
  6. alpo
    alpo
    Well?????
    Any updates??
  7. scrappybunch
    scrappybunch
    from nj
    I know older post.
    Check the leads on the pickup coil, those are known to break internally due to the vacuum advance movement. The insulation will look good but the copper strands are broken. Give a lite tug on them.
    Oh does that bring back memories of the good old days:(
  8. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Most of the aftermarket HEI's are Chinese JUNK. I'd run an old GM unit before wasting money on them.
