HEI Testing on Allen Syncrograph
Discussion in 'The Hokey Ass Message Board' started by dragracer439, Jan 7, 2010.
  1. dragracer439
    dragracer439
    Can anyone tell me how to hook up a GM HEI to my Allen Syncrograph? I suspect I need some type of pulse amplifier. Here is what happens; I run 12v power to the power wire on the 3 pin plug & hook up the signal wire from the syncrograph to the trigger wire on the HEI plug and run the ground to the distributor body. The machine will strobe for a few seconds then go out:confused:. I can disconnect & reconnect the power (or ground) and repeat with the same results?
    I know the Sun machines had an amplifier that could be used with electronic distibutors. Can I use one of these with my machine? Any help would be greatly appreciated, as I know this won't be the only HEI I see.
  2. convx4
    convx4
    I am working to solve the same problem.
  3. dragracer439
    dragracer439
    No, it doesn't work the same way. That has been the terminal I was trying. I only get enough signal to light the machine for a second or two the it fades out.
  4. Check with GMCBubba i think he uses that machine
  5. convx4
    convx4
    Got mine going Pm me if You need help
  6. emma351
    emma351
    hi convx4 I have been trying to get a message to you without much luck
    if you read this. yes please send me the wiring diagram for the amplfier my email is emma351@dodo,com.au
    thank you skeeter
  7. carmuts
    carmuts
    Guys, I just found Allen Operating Instructions for a Model E-316 syncrograph and some other Allen test equipment. Wished I would have loaded the syncrograph machine out of that old shop, but it was nearly destroyed as it sat. It is likely that it has gone to the scrap by now, but will be checking on it later this week. Rod
  8. oj
    oj
    Slightly ot but i have an old allen scope/analyzer that came from a dealorship in the '80's i'd say. Its a good sized machine. I tried to get it operating but couldn't get the trace working, it took it apart and found a burned foil capacitor in the pickup for the plug wire. I gathered up a sun scope and now the allen needs a new home. If anybody wants it shoot me a pm and cover shipping. it has all the accessory harnesses and timing light etc, no manual. Include your email in the pm and i'll send you pics.
    I never replaced the capacitor and it still don't work.
  9. "THE BURNNER"
    "THE BURNNER"
    from Dallas, Tx
    Do you still have this tester?
  10. tom19
    tom19
    Can anyone help me with a Allen distributor test machine I just got it does turn on and run it has three lead wires a machine ground a coil ground and another lead that it red but it don't seem to have any power on it?I am wanting to work with gm hei distributors I am assuming I need a pulse almplifier does anyone have wiring instructions how to use a hei moldue or Ford duraspark box to work the strobe?this is a E319bo
  11. KEVIN45704570
    KEVIN45704570
    Hi All, did anyone have any luck getting their allen machine going either with points or HEI? im interested in doing the same thing with mine.
  12. @convx4 , can you help prior poster?
