Hot Rods HEINIE puller ?
Discussion in 'The Hokey Ass Message Board' started by FANTM58, Apr 19, 2016.
  1. FANTM58
    FANTM58
    OK I picked up these 2 old puller from an Estate sale last weekend.
    Does anyone know what there intended use is ?
    Im thinking automotive .
    the first one looks like some kind of double puller .
    and the other is really different. it has a patend date of July 6th 1920 MFG-Heinie Puller
    Any ideas ?
  2. squirrel
    The double puller..you use one set of jaws at a time...
    I'm not quite sure how you'd use the Heine puller, but I don't have any medical training.
  3. slack
    slack
    Heinie puller. Gotta keep that thang tuned.
    The only patent listed for that date was for a Heinrich Heine (no "I") and is listed simply as "bearing puller."
  4. stimpy
    stimpy
  5. FANTM58
    FANTM58
    OK
    upon closer inspection of the double puller, Yes I see the arms are removable and reversible.
    So I stand corrected, it is not a double puller .
  6. bchctybob
    bchctybob
    Maybe a Heinie Puller was what they used in the Roaring '20s, before the Brazilian **** Lift was invented?
    The inside jaws on the one puller look like they were made for pulling brake drums from Nut& Key tapered axles like old Fords and Studes.
  7. Bruce Lancaster
    Bruce Lancaster
    My guess on the double is that the arms with the curved tips are designed for pulling early Ford hubs by gripping the puller groove. They are very similar to the Ford arm set used in the Snap-on "Dreadnaught" puller.
  8. BJR
    BJR
    Or may have been a tool used on the railroad for servicing engines or rolling stock.
