Hello from WV!
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by LLGarage, Mar 26, 2016.
  1. LLGarage
    LLGarage
    Hi, my name is Cody. I basically reposes furniture for stores like Mckinneys/RAC/Eagle when people decide to quick paying, its a terrible job. I'm currently going to school for a two year metallurgy degree. I have an addiction to cars, I bought my first when I was 16, I'm now 21 and can say I have probably had in the area of 20+ since then. I generally only had 2-3 at any given moment, I love to find things broken and fix them. Most were sub 2k cars, going to school I don't really have a lot of cash and those were always the easiest to flip because of the area I live in.
    Enough about me, I currently have a 79 Supra with a 4m-e 5spd, a VG30ET/5spd z31 swapped Nissan S12 which is my primary drift car and my 1986 Nissan 300ZX. It has a plain Jane Vg30 that is on it's last limb. I got the car for around 800$. It was either lit on fire or had actually had a pretty serious engine fire due to the recalls they had on the fuel injectors. Turns out Z's are about as flammable as your average Fiero. I rewired the Engine to spec with a FSM and am still having plenty of issues. My solution was turning it into a track car, I've always wanted a Z for Track/Hill Climb use in Pittsburgh. Since then I have taken it down to bare metal, shot it with Diamond clear. Started a set of custom metal wide fenders and have just been working on the suspension. I'm hoping to whip up a rear splitter soon.
    Since then I have picked up a 350 SBC out of a 79 Chevelle and a NV3500 from a 2004 Xtreme Chevy with the hydraulic throw out and the top feed style linkage. The engine was 250$, couldn't p*** the deal up. And I have 400$ in the trans from starter to driveshaft complete with 90K miles.
    My current issue is after I removed the Flexplate from the SBC, (as it was a 700R4 swap) my flywheel for the nv3500 wont fit. It appears the centerbore is smaller than lip on the blocks rotating ***embly. I was reading that I probably needed a 168 Tooth flywheel anyhow and actually planned on replacing this Clutch/Flywheel setup. My only concern is my pocket is unfortunately not a bottomless pit and if I buy the wrong thing it will probably set me back a few months.
    If anyone has done a similar swap Engine/Trans wise I would love to have some insight, I have done some research but it would be better to hear it real time from someone else rather than just on a old thread before I make the purchase. Mounting everything in the car and reinforcing it will be the easy part for me, but when it comes to mating the two I haven't the slightest idea. Thanks a million guys, Looking forward to becoming an active member of this forum!
    *I've uploaded a few pictures of it and the setup I have been working on, although they are all totally in the wrong order.
  2. LLGarage
    LLGarage
  3. cam the man
    cam the man
    I am anew member too, joined a while back, and I am also from West Virginia, I live about a half an hour north of Charleston. I am now 16 years old and my grandfather gave me a big project, a 1940 Chevy pickup, which I plan on turning into a restomod and will hopefully get started on it soon, I am like you, my pockets are not bottomless, so I need to find parts as cheap as possible and do as much of the work I can on my own, that will hopefully get the price down a
    bit, and good luck on your project.
  4. LLGarage
    LLGarage
    If you need any 216/217 parts I most likely have extras! I have three tore down, the other one is in my 41 DeLuxe. Nice to see someone from the area, good luck man!
  5. cam the man
    cam the man
    Thanks, I will need a lot of luck, I am planning on saving up enough for an ls swap if I get lucky and find a solid used motor that I can get cheap
  6. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    VG30ET,Nissan,Supra?? What the hell is this guy talking about? Must be some kind of furriegn stuff
  7. cam the man
    cam the man
    It is foreign, Japanese cars actually, they are usually really reliable, if you have never heard of Nissan or the Toyota Supra you must live under a rock
  8. LLGarage
    LLGarage
    Well we can't all be driving around the same cars, I mean i'd find it pretty boring if I went to a local show and it happened to be that we were all turning wrenches on the same blue 65 mustang.
