I just put in an order for a radiator from walker for my 28 on 32 rails with a 59AB. The guy on the other end said I want a 2 shorter radiator for a 28-29?? I thought I read on here that the 30-31 takes the 2 chop and a 28-29 takes a 3 chop???? http://www.jalopyjournal.com/forum/showthread.php?t=88742 They wont start until Monday so I have a few days to get to the bottom of this and or change my mind if there is a better radiator choice out there. I dont have my body on the frame yet so I have no way to measure. What is the correct height for the radiator? Thanks Chris
Where the rad mounts to your front crossmember is slightly higher on a '28-'29, than a '30-'31. But not by a full inch. Get the 3" chop and you can always raise it up on rubber mounts.
I agree - on mine I ended up somewhere between a 2 and 3 inch chop required. 3 inches should definately do it. Mike
