Help: 1948 Caddy flathead v-8
Discussion in 'The Hokey Ass Message Board' started by snot275, Jun 14, 2012.
  1. snot275
    snot275
    So, trying to get some more info on this thing but not much is coming up...
    trying to figure out if it is within my 38-48 range. The owner says:
    "Hi, The only number on the case is 1029 which I think is a date code. I have used these Caddy transmissions on Oldsmobiles for years and as far as I know all of the '40's and '50's cases and gears are the same. On this transmission the tail shaft housing measures 14 1/2 inches from the case to the oil seal. I'm sure this will work in your '48 Caddy. I hope this helps."
    Still not quite sure though... Here are some pics, you guys let me know what you think please. I've been doing a lot of reading and comparing pictures but I just dont have the experience to pick apart pictures successfully...
  2. RichFox
    RichFox
    Yes it should work if it came from a Cad or Olds V8. Of course you will need the stick bellhousing and clutch parts. I hope you realize the Flathead cad is a very heavy engine and the model A frame was never made to carry that much weight. What are you doing to reinforce your underpinnings?
  3. fiftyv8
    fiftyv8
    from CO & WA
    Good point Rich, in my project with the Cadillac flathead engine, I boxed the frame and used a model A truck front crossmember.
  4. snot275
    snot275
    Yes, I'm aware of the bellhousing, pressure plate, and clutch, and am tracking some down now... As far as the frame goes, I wasn't very comfortable running the Model A rails, even boxed, so I built (still in the process) new rails out of .120 wall 2x3 steel tubing. She'll be STRONG :D Thanks a lot for your help/advice!
  5. snot275
    snot275
    Here's a question for ya Rich (or anyone in the "know")... I know the 50 Olds housing won't work because it only fits on the OHV and later engines (i think), but I think I'm ok to ***ume that any caddy/lasalle housing from 38-48 WILL work? Is that correct? I've heard of some issues with the '37 being a weird year but everything else 'should' be ok?
    thanks again guys.
  6. RichFox
    RichFox
    I think any 38 to 48 bell housing will fit. But I sure don't have actual hands on experience with that many flathead Cads
  7. snot275
    snot275
    Ok, thank you
  8. 38FLATTIE
    38FLATTIE
    from Colorado
    Chris, I just bought a complete, runable, engine and ****** setup. I need it for mockup in the FlatCad.
    If you can be a little patient, when I get done with it, you can have any of the ******, bellhousing, and clutch setup you want, if you'll pay the shipping. I'm thrilled to see more and more of these being built!
  9. roseville carl
    roseville carl
    now that sounds like an offer that can't be beat!!!
  10. snot275
    snot275
    Wow Buddy, thanks a lot for that! i picked up a '37 Lasalle toploader. The bellhousing and clutch set up I have are from a 38-48 side loader though, but I don't think that matters and should mate up anyway, correct? Granted, I need to get a new clutch disk anyway because this one looks pretty ate up, and the pressure plate may need to be replaced as well... Getting there, I guess, just slowly haha.
