Technical Help 3 speed tranny popping out of 2nd
Discussion in 'The Hokey Ass Message Board' started by bpenderg, Mar 20, 2017.
  1. bpenderg
    bpenderg
    I recently had my transmission completely rebuilt with all new gears. I read an older post but wonder what I need to fix? Any suggestions? It pops out unless I manually keep it held there. Is there a kit II need or a new shifter? Is this easy to fix without pulling the ******? Suggested source for the parts? Thanks!
  2. Wonder what kind of car and transmission.....
    Such a common problem I guess it's safe to ***ume.....
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ok you said new gears so I'm going to say the little teeth on A isn't your issue. Now look at D, the slider. The internal teeth on D could be worn to a point and that can cause what you are experiencing. [​IMG]
  4. squirrel
    did it pop out of gear before the rebuild?
    The usual cause is the edges of the little teeth on A being worn, and especially, the sides of the grooves inside D being worn.
    Johnny Gee likes this.
  5. inthweedz
    inthweedz
    A couple of things come to mind... It's usually the gears that have been mentioned above (back in the day, the shop where I worked had a machinist who would undercut (grind a reverse taper) on both the inner and the outer corresponding gears ..
    Secondly.. Have the detent balls and springs been fitted?? Maybe a spring is broken, or needs a heavier tension..
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Good call
    Paul likes this.
  7. tb33anda3rd
    tb33anda3rd
    repop parts?
    detent balls and springs in place?
  8. Paul
    Paul
    Editor
    What transmission?
    Shift tower or linkage?
    Column or floor shift?
    Heavy shifter?
    Does it do it all the time, or only on deceleration like when going down hill?
    Do you use second gear to slow you down?
    lothiandon1940 likes this.
  9. bpenderg
    bpenderg
    It did pop out before rebuild. Floor shifter. ****** from 49 F1. It seems to do it when there is more pressure on 2nd. It isn't all the time, but most of the time. Down hill especially.
  10. squirrel
    Do you have a list of the new parts that were installed?
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>It pops out unless I manually keep it held there.>>>
    A dash hook automatically solves that problem. 8^) Jack E/NJ
  12. squirrel
    if the trans builder is any good, a warranty solves the problem, as well.
  13. banjorear
    banjorear
    Common with these F1 transmissions. Like the above have mentioned, it could be one or all of the issues. Cheap quality br*** synchros can also be a cause of the problem.
    I'd give Mac Van Pelt a call. He's a Ford 3 speed trans. guru and will sell you quality parts to fix this.
    The combination of worn or cheap parts, heavy car, gear ratio, rear ratio puts a lot of stress on 2nd gear. If everything isn't up to snuff, it will pop out.
    tb33anda3rd likes this.
  14. alchemy
    alchemy
    Too much clearance at the ends of the ***embly to the case. Reshim the ***embly properly. If you are going to do it yourself, get the book from VanPelt showing how to do it properly. It's well worth it.
    tb33anda3rd and squirrel like this.
  15. banjorear
    banjorear
    True. I forgot to include this important aspect of the rebuild. This is something you should be able to check right now without taking the trans out.
    To confirm, was this trans rebuilt and is still giving you the issue or it in the truck giving you the problem?
  16. tb33anda3rd
    tb33anda3rd
    i have found you need to measure every new part you buy. the junk varies and as what was stated play between the input and out put shaft will wreak havoc, popping out of gear or hard shifts.
  17. dfriend
    dfriend
    from B.C.canada
    Hi
    What keeps the slider from jumping out of mesh is the three dogs and spring on the slider and there mating gears if the gears,shafts and sycro rings are not worn
    . You can take the shifter and put the slider in gear and drive it and it will not jump out. The detent and balls in the shifter do not keep the transmission in gear.
    Take the transmission back to who ever repaired it (IT WAS NOT REBUILT) and have it rebuilt
    Regards
    Dave
  18. Blues4U
    Blues4U
    from So Cal
    I had a Muncie 4 speed in an OT car that would pop out of 2nd gear on deceleration unless I accelerated slightly after shifting into that gear before decelerating. It was pretty tricky on hard down shifts/fast braking conditions. I'd have to stab the throttle as I released the clutch, then release the throttle and jump on the brakes real fast. Made for exciting times...
  19. Gman0046
    Gman0046
    Worn syncros cause popping out of gear.
    Gary
