Technical Help 30 model a coupe inner door release.
Discussion in 'Traditional Hot Rods' started by bigvinny, Mar 16, 2014.
  1. bigvinny
    bigvinny
    :confused:trying to figure out what I need for inner door latch controls. All I have is the inner handles. cant find a good parts drawing for inner latch to see what parts I need and how to put it together. Any help would be great!
  2. acme30
    acme30
    from Australia
    Model A coupe inner door release is very simple the inner handle just attaches to a long round rod that goes to the door latch. As you lift the handle up it rotates / turns the rod that effectively pushes on the catch and releases the door.
    Sorry haven't got a picture handy but CW Moss, and MAC's sell them repro. Macs have an online catalog so you should be able to find a picture of the latch pretty easy.
    Edit
    Here is a link to the part at mac's
    http://macsautoparts.com/model-a-fo...p-right-a46105b/camid/MDA/cp/JS0R3CHL1066009/
    Bit hard to tell from the picture but the actual part of the latch that catches on the striker has a tab on the inside - that is the bit you can see at the back of the latch on the left hand side of the picture. When you lift the handle it rotates the rod that goes to the latch and pushes on the back of the latch
  3. bigvinny
    bigvinny
  4. tim o'connell
    tim o'connell
    Vinny , snyders antique auto parts in new springfeild ohio has a complete kit that does both doors for $29.95 part #a-70241-a comes with the mounting plates , rods and springs , they also have new handles and escutcheons if yours are crusty . you also need the small sleeve nut to attach your handle to the rod part #a-702400-sn . they're phone # is 888-262-5712 , hope this helps
  5. bigvinny
    bigvinny
    I found the rods in box of parts that came with car, but I dont see how they hook into latch, I may need to find more pieces. I wish I could find a picture of how it goes together
  6. bigvinny
    bigvinny
    I looked at the picture at macs and I see the clips that hold rods to the door but not sure what the little round springs are for.
  7. Firecat7
    Firecat7
    Spring returns the handle to vertical inside;)
  8. flthd31
    flthd31
    Here's a couple pics for ya
  9. bigvinny
    bigvinny
    thank you.that's what I needed. I thought it went inside the door.
