help, 34 ford are 4 door front doors the same as a coupe 5 window?
Discussion in 'The Hokey Ass Message Board' started by Kustchops, Mar 21, 2005.
  1. Kustchops
    Kustchops
    I got a pair of realy nice doors off the front four door sedan, they look the same as a coupe with out the rear corners rounded. Am I on crack or did ford do a slight mod to make them fit. I got doors any one got a bod?
  2. The37Kid
    The37Kid
    The 4 door doors are shorter than a 5window.
  3. titus
    titus
    I thought they were the same lenght just has a taller window opening.
    same with 32 5 win and 4 door front doors.
  4. 5-window coupe and 4-door doors are the same length....the only difference is the upper rear part of the door, right above the upper hinge is a little taller , but is easy to modify
  5. Roza
    Roza
    The difference in the doors is between the top and middle hinge. If I remember the measurement on the 5w is 187/8 from the top of the top hinge to the bottom of the middle hinge. I think the four door is 191/4.
