" Help",8BA Flat Head, 32 frame
Discussion in 'The Hokey Ass Message Board' started by chopnchaneled, Jul 24, 2008.
  1. chopnchaneled
    chopnchaneled
    from Buford Ga.
    what water pumps and fan do i need to put a 8ba flathead in a 32 frame and a 32 body and still run the stock hood top.
    the engine is a 8ba, with a 39 gear box, and stock 32 crossmember.
    thanks for any help.
  2. Dirty Dug
    Dirty Dug
    Truck pumps. They come wide belt so you'll have to plan for that. I use a '49 generator and '49 Merc fan. They both have wide belts or you can have narrow pulleys installed on the pumps.
  3. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Thanks for the reply, one question, you said you ran a 49 gen. and a 49 merc. fan,
    is the fan mounted on the gen???
    thanks again
  4. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Second opinion: Yes you need the Truck Water Pumps...
  5. Dirty Dug
    Dirty Dug
    The fan has it's own pulley and mounts to the generator mount.
  6. Bruce Lancaster
    Bruce Lancaster
    Two ways that are easy: Stock '32 mount brackets (rare$, reproduced, can be made), bolt on after the most minor grinding, OR truck pumps plus simple tabs off frame rails like Hurst A-28 mounts so they have a seat. "32 original mount pads in crossmember are in totally wrong place for route #2.
  7. tommy
    tommy
    Here is mine. Truck pumps with a 49 car fan or a 49-53 truck fan with the wide belt. I got a little more room by drilling out the stock fan blade rivets and bolting a flat after market flex fan to the fan hub.
  8. vintagehotrods
    vintagehotrods
    You can use later Mercury 8CM water pumps that are much like the truck pumps but with narrow pulley's that will allow you to use the narrow belt setup. The Merc pumps will set the engine lower so you'll need to space the biscuit frame mounts up 1 1/2" with some spacers. I can supply pics of this set-up if you need them. I used to be able to get the Merc pumps from NAPA.
  9. chopnchaneled
    chopnchaneled
    from Buford Ga.
    A great big thanks to everyone.
    Tommy the pic. is great, a very good looking eng.
    Thanks Again
