Technical HELP Assembly Manual Page Needed
Discussion in 'The Hokey Ass Message Board' started by bgreene30, Oct 28, 2014.
  1. bgreene30
    bgreene30
    Hi everyone,
    There is a broken bolt holding the harmonic balancer and single V groove pulley on my uncles 48 straight 8.
    Does anyone have a page of the ***embly manual showing the parts there? obviously balancer and pulley.
    Going to try to remove the pulley and balancer ***embly with a puller hoping there is a nub left of the bolt I can grab onto.
    Any help appreciated.
    Cheers,
    Bob
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Straight 8 what ? Buick, Olds, Pontiac, other ?
    Don
  3. X38
    X38
    Ha ha!
    My first thought too.
  4. bgreene30
    bgreene30
    Oops. Pontiac!
  5. bgreene30
    bgreene30
    Oops. Pontiac
  6. Frank Carey
    Frank Carey
    Motor's Manual, twelfth edition - 1949
    "Vibration damper, 1935-1949
    The unit is removed from the crankshaft by a special puller. The starting crank nut which holds the balancer in place at the end of the crankshaft is recessed and can be turned off by inserting a 3/4" hexagonal bar, except on the 39-48 models. On these models, remove the damper retaining screw with a suitable socket wrench."
    The only picture is a "long section" of the 8-cyl engine. I'll scan it later and see if I can enlarge the area of interest. It might help.
  7. Frank Carey
    Frank Carey
  8. bgreene30
    bgreene30
