Technical Help! Brake fitting question
Discussion in 'The Hokey Ass Message Board' started by FatfenderJ, Feb 13, 2022.
  1. FatfenderJ
    FatfenderJ
    Replaced the master cylinder and now can't get this fitting tight enough. I dont want to snap it off which feels like where I'm at. Ideas? 20220213_085938.jpg
  2. RICK R 44
    RICK R 44
    Are you sure that you are using the correct fitting and/or the proper flare?
    427 sleeper and squirrel like this.
  3. squirrel
    I think the hole is 1/8" NPT. If the fitting is also NPT, but worn, it might not have it's original taper any more, and won't tighten gradually like it should. In that case, you need a new fitting.
    Pist-n-Broke likes this.
  4. What Squirrel said!!!
  5. kabinenroller
    kabinenroller
    Are you sure a single master cylinder is the right choice? While you were replacing the MC a dual cylinder would be a safer choice.
    Just my opinion
  6. If it's plumbed right and worked well till it was worn out, I wouldn't change a thing.
    egads, Jeff Norwell and VANDENPLAS like this.
  7. bchctybob
    bchctybob
    Is that a pipe thread in the end of the M/C? Or is it an inverted flare and an inverted flare fitting? If it’s an inverted flare, I think they make “seat savers” that go in before the fitting that might just shim it to a better position rotationally. I don’t remember where I’ve seen them but I was surprised to see that they make them.
    If it’s just a common 1/4” pipe thread, sometimes you can tighten and loosen it a few times and gain a little rotation with each cycle.
    Take the fitting out and take a picture of the end of the M/C.
  8. 427 sleeper
    427 sleeper
    Please tell me that you're not using an aluminum fitting in the master cylinder... :eek:
    2OLD2FAST likes this.
