Help! broken bellhousing bolt
Discussion in 'The Hokey Ass Message Board' started by Devin, Dec 29, 2012.
  1. Devin
    Devin
    from Napa, CA
    I was just snugging up my bellhousing to my block (SBC) when one of the grade 8 bolts snapped off inside the block. I don't think I excessively tightened it it just snapped. I have had bad experiences with EZ outs in the past so I did a search here on extracting broken bolts. I tried the weld (MIG) a nut to the bolt trick. The nut sheared off and Im afraid that I welded the bolt to the block as it tried sanding it down and can't differentiate between the bolt and the block any longer. I thought that the iron block wouldn't allow the weld to stick?
    Am I fucked? all advice is appreciated.
    Thanks
  2. el Scotto
    el Scotto
    from Tracy, CA
    That sucks!!! :p
    Try drilling it out, you may get lucky!!
  3. inthweedz
    inthweedz
    Thats a bitch..
    But can you get a centre punch on the outer edge of the bolt to try and turn it??
    Or maybe cut a decent slot cut across the end showing, and use an impact screw driver??
    Otherwise, as elscotto said, drill it the in centre (right thru) start with an 1/8" drill ( small drill is easier to work in the centre of the bolt) then work up drill sizes..
  4. Jokester
    Jokester
    Use a left handed bit too. That sometimes helps.
    Really, there is such a thing.
    .bjb
  5. flamedabone
    flamedabone
    It sounds like the bolt bottomed out in the hole then snapped. Usually if it is bottomed out, it won't come out the easy way...
    Your best option is to drill it. Start with an 1/8 bit right in the center turning nice and slow with lots of lube. Next, go to 13/64 or so, then finally, 5/16. After drilling, damn near all the bolt will be gone and you can either pick out what is left, or run a 3/8 bottoming tap in the hole and all will be well.
    For your situation, I would stay away from an easy out and be carefull with the tap also. Taps and easy outs are about 40 on the Rockwell C scale (hard as woodpecker lips) and if you break one, you will NEVER be able to drill it out.
    Be carefull, go slow and you will be fine.
    Good luck, -Abone.
  6. 56don
    56don
    Put the bellhousing on it and use the hole in the bellhousing as a guide for a left hand twist drill to drill it out.
  7. bobss396
    bobss396
    If you have access to a lathe, make up a series of bushings to fit the hole and that will keep the drilling on center. Or keep opening the bushing as you change drills. Go with 1/8, 3/16, 1/4. From there be careful since the tap drill for a 3/8-16 is a 5/16.
    Bob
  8. Devin
    Devin
    from Napa, CA
    I'm going to try and find a left twist drill. theoretically, the weld should not stick to the block though, am i correct?
  9. bobss396
    bobss396
    Try hitting it with a chisel. I buy my LH drills at MSC Direct, you may need an account though. They are also known as screw machine drills.
    Bob
  10. F&J
    F&J
    No, it will stick, but will be very brittle at the joint.
    Next time, don't use grade 8, and make sure it is not too long.
    Also, you should have welded a 3/8 flatwasher to the bolt shank first, starting with a high heat at the center, and then pile it right on, and then cover the washer, too, before you stop. Then weld the nut to the washer. That would have shrunk at least the top part of the bolt. Let cool completely. Then rock it back and forth to get it to move a bit. Takes practice to not snap it.
    I am not sure if I would drill. (depending on what it looks like now) I might trying smacking the end with a 5/16 flatnose punch to maybe break that brittle weld line. Then do the washer and nut.
  11. 40FordGuy
    40FordGuy
    Ditto, 56 Don's post. LOVE those left hand drill bits !!!!!!! And, use the bell housing as a drill and center punch guide
    4TTUK
  12. 39 Ford
    39 Ford
    You can try the slob approach and install the bell housing using the other bolts and just drive it. Sometimes you can do more damage attempting to correct a problem. Who will know except a few thousand of us.
  13. Devin
    Devin
    from Napa, CA
    The reason I did not try the washer was because the bolt was recessed inside the hole. I am a little reluctant to try welding again as I'm concerned the weld will stick to the threads. Thanks for he advice
  14. bcowanwheels
    bcowanwheels
    You can also put some spot heat on the boss to relax it before you use the l/h bit.
  15. F&J
    F&J
    If it is recessed a lot, that complicates the drilling. By welding to the top, it most likely burned into the block threads a lot, and the weld material will be stuck real good to the bolt. As you try to unscrew the bolt after drilling, those globs will be locked into burned pockets in the threads...just like a key holds inside a keyway.
    You may have to drill oversize, like 3/8 size bit, to take out all of the melted threads and a bit of the bolt shank. Not an easy fix at this point, unless you were good at centering the hole, and drilling it all out for a helicoil.
  16. I'd probably leave it if it was one of the top ones. and I agree with F&J... don't use grade 8 bolts. No reason to.
  17. Harvey29
    Harvey29
    from kansas
    How about if all else fails, try using a heli-coil?
  18. dorf
    dorf
    from ohio
    probably wont bother anything. id had surgery so i paid a local chevy garage mech to put a clutch in my s10 , i was under it a year or so later and they left a bolt out of the bellhouing. sold it six years and over a hundred thousand miles later . no problem
  19. philjafo
    philjafo
    from right here
    i know most guys prefer to do things like this by themselves, but if you've welded it to the block try calling a machine shop to get a price quote, I would think it should be cheaper then a new block, and you'll end up with all of the bolts holding your motor and trans together.
  20. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Out of curiosity, why the recommendations not to use grade 8 bolts? Because they are hard to drill out in cases like this?
  21. Skeezix
    Skeezix
    from NorCal
  22. noboD
    noboD
    Buy a $10 set of transfer punches from a Co. like MSC. USe the bellhousing as a guide to mark where the hole is. Then drill it. Or use a Dremel to remove your weld, then procede with trying to get the bolt out.
  23. Mr48chev
    They aren't needed or necessary, GM built millions of cars and trucks with grade 5 bolts holding the bellhousings on. Overkill just for the sake of overkill doesn't really accomplish anything. That they are harder to drill out really isn't the issue.
  24. 283john
    283john
    Left handed bits, no easy-outs. Some shops can use Electronic Discharge Machining to get them out. I'd probably try driving it one bolt short, though.
  25. R Pope
    R Pope
    A small tip cutting torch will blow the bolt out and not hurt the block. Might need a helicoil to get a bolt threaded in it after, though.
  26. VoodooTwin
    VoodooTwin
    from Noo Yawk
    So they shouldn't be used here because they are too brittle for the application, as noted above? Trying to understand, before I button mine up.
  27. 56sedandelivery
    56sedandelivery
    Blow it out with an O/A cutting torch, and retap the hole after. Butch/56sedandelivery.
  28. Bud Reynolds
    Bud Reynolds
    The coolest thing I ever saw on stud removal was in a muffler shop. Several years ago I dragged home a 1932 Chevy coupe and the engine ran good but the exhaust was junk. I would almost bet the stud in the exhaust manifold was original and the nut was frozen to the stud. I took the coupe to the muffler shop and the mechanic did not even attempt to take the stud out, instead took a torch and heated the mainfold around the stud cherry red. He then threw a styro-foam cup full of cold water on the stud and manifold, put a socket on the nut and the stud backed right out! He repeated this on the second stud the same way and got the same result. I have no idea how it works but I saw it..
  29. Devin
    Devin
    from Napa, CA
    Heli coil did the trick. I was lucky to be able to drill on center. I'm pissed that I made such a stupid mistake and wasted my day trying to fix it. Lesson learned lol!
  30. bobscogin
    bobscogin
