Help! broken bellhousing bolt
Discussion in 'The Hokey Ass Message Board' started by Devin, Dec 29, 2012.
  1. Devin
    Devin
    from Napa, CA
  2. CTaulbert
    CTaulbert
    from Detroit
    The bolts are only there to provide a clamp load. The clamp load is what prevents the engine and transmission from moving relative to each other. The bolts do not transfer the torque from the engine to the transmission. The moment the clamp load reduces, you'll shear the bolts.
    Long story short, it really doesn't matter what grade of fastener you use, as long as you can achieve the proper clamp load with them.
  3. bobscogin
    bobscogin
    The bellhousing dowels will prevent the bolts from taking the shear load.
    Bob
  4. gimpyshotrods
    gimpyshotrods
    Dude, it happens, to all of us. I have lost track of the number of stuck/broken fasteners I have had to remove.
    You learned. Now you have a new skill. The day was not wasted.
  5. Halfdozen
    Halfdozen
    Bingo. Grade eight bolts are stronger in tensile and shear strength than a grade five (or lower) bolt. They are still ductile, they are tough, not hard and brittle. Grade eight might be overkill here, but it won't hurt to use a higher grade bolt. A grade five will break at a lower torque if you bottom it in a blind hole.
  6. Devin
    Devin
    from Napa, CA
    Quite true! Thanks
  7. 55 dude
    55 dude
    i work on machines that are stainless steel and once in awhile somebody puts in a stainless bolt that ends up galling the threads and they break off the bolt. i have found using a dremel tool with small carbide bit to put slot in broken off bolt then a little heat with a screwdriver will usually get the broken part out. the process is slow as can be and i use this on regular steel bolts also.
  8. Commish
    Commish
    from NW Ok
    No, they are not brittle, and may not be required, but perfectly acceptable to use. A little overkill never hurt anything in that kind of situation.
  9. greg
    greg
    I just had a guy at work do the exact same thing. After he threw the water on it he worked it back and forth easily and got them out. It amazed me how that worked!
  10. Truckedup
    Truckedup
    No argument on using a grade 8 for the bell housing....But..I believe that when Lakewood ****ter shield bell housings first came around they included grade 5 bolts and a disclaimer or maybe NHRA rule not to use grade 8 because they would break too easily from a flywheel explosion.Anyone ever hear this?
  11. willowbilly3
    willowbilly3
    from Sturgis
    Left hand drill bits and drill guides are almost always my first choice, not after it is all ******ed up from other butchery. Some guys claim the welding on a nut trick works but I NEVER had that work, ever and then you have a mess.
    Any good hardware store should have left hand bits.
  12. Bigchuck
    Bigchuck
    from Austin, TX
    "Time-sert" is another option. They work very well.
  13. no.scar.no.story
    no.scar.no.story
    I did service work for while on some industial equipment. A guy I worked with there would remove a bolt that was broken off below flush by welding a piece of steel tubing to the end of the broken bolt. He stuck the welding rod down the inside of the tube while holding the tube in the hole against the end of the bolt. The tubing made the new "handle" for turning the bolt and protected the threads from the weld splatter, etc. Turned it out with a small pipe wrench. Worked like a charm for Charlie.
  14. Bud Reynolds
    Bud Reynolds
    Thanks Greg for verifying this. You have to see it to believe it. Apparently the stud cools faster than the manifold, shrinking just enough to break loose.
