Help, can I change input shaft on Doug Nash 4+1 transmission?
Discussion in 'The Hokey Ass Message Board' started by Kail, Jan 17, 2012.
  1. Kail
    Kail
    from Austin, TX
    I needed a trans to complete my 34 truck build, my dad will trade me a Doug Nash 4+1 trans that is like new. Problem is it was setup for a 426 hemi and has a 18 spline input shaft. I am running a Pontiac motor that had a th400 Can I change this? And can I possibly use Richmond parts since they bought them out? I like the ratio and strength of this trans.
    Thanks, Kail
  2. seb fontana
    seb fontana
    from ct
    I'd call Richmond and ask..My memory says Mopar was the oddball in ratios so the input may have different tooth count than GM but mabe the cluster drive gear could be changed too....Maybe and adaptor/bell housing?
  3. Atwater Mike
    Atwater Mike
    Use an 18 spline clutch disc and GM pressure plate.
  4. NAPA 68
    NAPA 68
    beat me to it!
    x2
  5. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    The GM input shaft is 6.66 inches long. The Mopar is 8.57 inches long.
  6. Brad54
    Brad54
    from Atl Ga
    I've got an old Super Stock Mopar trans that was built to go behind a Chevy: they turned down the input shaft length and pilot diameter to fit with a Chevy bellhousing (I have a blow-proof lakewood that had Mopar mounting holes added to it)
    I don't know what the front of the Doug Nash trans looks like for your application: you may have to have an adapter made, which I would guess will be 1/2-inch or maybe 1-inch material.
    Take the trans apart and have a machine shop turn the input shaft down to the right diameter, then go with the 18-spline clutch disk.
    Also, I would imagine the bearing retainer on the front of the trans will be the same diameter as a Mopar piece, to register in the bellhousing's hole.
    The Chevy is a smaller diameter: on my S/S trans, and the New Process 4spd OD in my Suburban, that bearing retainer O.D. had to be turned down .250-inch to fit a GM bellhousing. I also had to use four allen blots/cap screws to retain it, as the heads on hex-head bolts interfered with the hole in the bellhousing.
    -Brad
  7. Kail
    Kail
    from Austin, TX
    Thanks guys. This gives me somewhere to start. I emailed Richmond today as well.
