Help cutting a long bed Studebaker down to a Short bed
Discussion in 'The Hokey Ass Message Board' started by The Moonshiner, Jul 9, 2011.
  1. The Moonshiner
    The Moonshiner
    from NC
    Does any one know if this is possible? A friend has a LWB 49 Stud 3/4 ton truck with the entire running gear from a late model Suburban (454) but we want to cut it down to a SWB. Its still on the origional frame also.
    Thanks.
  2. angry
    angry
    from ventura ca
    yes it is
  3. The Moonshiner
    The Moonshiner
    from NC
    Sweet. Any tips on getting it done? Did you do a thread or got some notes? First time try on this for me.
  4. raidmagic
    raidmagic
    Oh GOD I want that!!!!!! Bad ***!!!!!
  5. michaelvz51
    michaelvz51
    from So Cal
    I have done many truck 4x4 conversions in the past and the best tip I can offer when cutting a frame to shorten it is to cut it at about a 45 degree angle. DO NOT cut it vertical at 90 degress or it will stress crack. After you do the 45 degree cut, add a "fish plate" on the inside of the frame and "skip weld" it all together. DO NOT weld it all in one shot. Most of the semi truck mfgrs. use this method also. Good luck and make sure you measure 3 times before you start cutting!
  6. The Moonshiner
    The Moonshiner
    from NC
    Good tips. I will take my time for sure.
  7. aircap
    aircap
    You could ask over on the Studebaker Truck Talk forum....
  8. slammed
    slammed
    How about Zing the frame and shortening it at the same time?
  9. slammed
    slammed
  10. angry
    angry
    from ventura ca
    when you do the bed drill out the spot welds on the end caps and cut to size and spot weld them back in the easyest bed to shorten by far
  11. jetnow1
    jetnow1
    from CT
    There is an how to on shortning a bed right now in the AD group- most should apply to any other make. Search posts by t.hudson. Jim
  12. The Moonshiner
    The Moonshiner
    from NC
    Thanks. Im still a noobie so where is the AD group?
  13. Knoxville
    Knoxville
    Click on Community up top, then Social Groups
  14. The Moonshiner
    The Moonshiner
    from NC
    It may be awhile before this one moves. He said he saw on the internet where one sold all fixed up for $84,000.00 Then I told him a short bed just sold on ebay for $2K bare bones with no motor. He didnt like that much.
    Heres some pics.
