Help decoding my 327?
Discussion in 'The Hokey Ass Message Board' started by punisher7, Sep 1, 2012.
  1. punisher7
    punisher7
    I have a 327 that I am trying to figure out what it came out of. On the rear driver side it has "3782870" just above it is "GM" and there is a 3 by itself. On the rear p***enger side the block has "L172". I have figured out that the block is a 62-65. Just curious if these numbers will tell me what kind of car it is out of? Are there more numbers that I am missing? ImageUploadedByTJJ1346524898.891919.jpg ImageUploadedByTJJ1346524934.900948.jpg
  2. randydupree
    randydupree
    from archer fl
    why do you care?
    Lets face it,after 40 years lots of things have been changed in that engine..
  3. sawbuck
    sawbuck
    from 06492 ct
    corvette .. ha ha
  4. punisher7
    punisher7
    What's wrong with knowing where it came from?
  5. henry29
    henry29
    Stand in front off the engine look to the left of the water pump in front off the head, post the numbers. If it's been decked the numbers will be gone.
  6. punisher7
    punisher7
    No numbers in front of the head
  7. Slick Willy
    Slick Willy
  8. upspirate
    upspirate
    As long as we have our secret decoder ring out!!!
    My block has casting # 3932386
    Serial # (near as i can tell) 196013939 then in different size V1105FC
    Who knows what's inside,but what was it originally just for grins?
  9. .... considering the suffix code has been milled off then I doubt if you have a numbers matching engine, at least they put the distributor hole in the right spot..
  10. Larry T
    Larry T
  11. upspirate
    upspirate
    Thanks Larry, I was checking some links, but didn't find those #'s exactly
  12. Larry T
    Larry T
    The block code will give you the year number (I just typed it in my search engine) and the FC suffix is on the Nasty Z-28 site that I posted a link too.
  13. upspirate
    upspirate
    Thanks again, I bookmarked that site so I don't have to ask again!!!
  14. Larry T
    Larry T
    Didn't mean to pick on you. The question comes up a lot (twice in this thread :D), just thought I'd throw the site out there, it comes in handy.
  15. upspirate
    upspirate
    You weren't pickin'....I learn't real fast to search on here before I ask anything!!!;)
    But figured I'd ask as it came up again.
    I had come up somewhere a while back that the casting # said 67-69 Camaro/Corvette performance 327 but the site you listed says b/f code body,Camaro/Biscayne,Bel-Aire etc.
    I just know it runs well, and who knows what has been done internally since then....and who really cares until/if I have to tear down,then I'll know what's really in there.
  16. 40FordGuy
    40FordGuy
    That number pad on the p*** side, front of the deck, may be recoverable by acid etching where the numbers used to be. When the numbers were stamped, the impressions can go beyond where they were visible. Can't hurt to try it.
    4TTRUK
