help dont know the size of my small block ford
Discussion in 'The Hokey Ass Message Board' started by ratrods_by_troy, Jul 19, 2009.
  1. ratrods_by_troy
    ratrods_by_troy
    from Indy
    The cast is 040E-6015-BA I just pulled it of a 1963 ford fairlane 500. and need to know what size please help.
  2. plodge55aqua
    plodge55aqua
    from Alberta
    If its a V8 , It should be a 260.
  3. ratrods_by_troy
    ratrods_by_troy
    from Indy
    or it might be C40E-6015-BA
  4. skipperman
    skipperman
    C4 is 1964 in Ford language ... and the 260 was the small V8 in that year.....
    ...... jersey Skip
  5. George
    George
    C40E-B is listed as a "high performance" (K code?) 289. C4 is 1964
  6. ratrods_by_troy
    ratrods_by_troy
    from Indy
    this motor isnt stock it has 4 pullys and only runs a alturnator and the water pump. i hope its a 302/. lol
  7. ratrods_by_troy
    ratrods_by_troy
    from Indy
    it has a 5 bolt bellhouseing?
  8. George
    George
    5 bolt up through '64. A K code 289 is a lot more valuable than any run of the mill 302.
  9. Spyder
    Spyder
    from Houston
    If it has has a 5 bolt bell housing, it's not a 302 block.
  10. ratrods_by_troy
    ratrods_by_troy
    from Indy
  11. George
    George
    If it's a K code you might find the original VIN stamped on it, possibly on the bell mount surface.
  12. George
    George
    K code was the VIN letter for the highly desirable 271 HP 289.
  13. raceron1120
    raceron1120
    If the casting starts C4OE (C4 = 64) it's not a 302 - they raplaced the 289s in '67/'68.
    A K-code 289 is a highperformance 289, mucho $$$. You've likely got a 260, or maybe a 289.
  14. Drive Em
    Drive Em
    K code was Mustang only, I have seen Comets with the "K" and they were regular 289's.
  15. George
    George
    Has beefier mains, bigger harmonic balancer, nodular iron crank, bigger valves. Used in Shelbys, Mustang GT
  16. havi
    havi
    Just for kicks, what color are the valve covers?
    BTW, K code Fairlanes had HiPo's, and 3 row radiators.
  17. ratrods_by_troy
    ratrods_by_troy
    from Indy
    do i have somthing i need to keep or what and if it is a 260 like plodge55aqua said every custom part i find is ford a 289 or 302 like valve covers and intakes i have 3 two barrel carbs i wanna run I thought about making a custom plate so it will just be a single 2 barrel but look like a six pack? <SCRIPT type=text/javascript> vbmenu_register("postmenu_4135892", true); </SCRIPT>
  18. George
    George
    Same year? say 65? OEM engine, or was it changed?
  19. George
    George
    All stuff basicly interchanges between the 260,289,302. If it is a 289 HP it's worth money to Mustang restorers.
  20. ratrods_by_troy
    ratrods_by_troy
    from Indy
    holley chrome valve covers
  21. George
    George
    a '64 260 would be of interest to someone restoring the early, so called '641/2 Mustang.
  22. ratrods_by_troy
    ratrods_by_troy
    from Indy
  23. havi
    havi
    Look at the numbers in the corners of the heads on top. Look for numbers like 19, 20, 21. Secondly look at the spacing of bolt of the upper half of the motor mounts. Either 6" or 7". Thirdly, if they are 7" and you don't have plans to use them, I'll gladly buy the whole motor mount ***embly. :)
  24. ROCKET88COUPE
    ROCKET88COUPE
    from TEXAS USA
    5 bolt bell housing --221-260 anymore holes and its 289-302
  25. George
    George
    '63 & 64 289s have 5 bolt bells.
  26. George
    George
    Pull valve covers & see what numbers are there.
  27. George
    George
    C40E-B is a '64 High Performace 289 block, as said earlier.
  28. T-Time
    T-Time
    from USA
    He said its a C4OE-BA. I think he's still misreading it. There is no such block number for a SBF, as far as I have seen and as far as I can find.
    By the way, according to one source, the C4OE-B block can either be a 260 or a 289 HP. Don't know if that's right or not. (The 260 will have a 3.80 bore size, and the 289 HiPo will have a 4.0. The 289 HiPo has the big, heavy-duty main caps.)
    EDIT: Yet another fairly reliable source (MustangTek) states that they have confirmed that the C4OE-B block was also used for the standard 289.
  29. Spyder
    Spyder
    from Houston
    To each his own, but if it turns out to be a K code motor and you put a fake tripower on it, that would be just Wrong. Bad mojo.
  30. havi
    havi
    The best iron content blocks were set aside to make the HiPos, thus the C4OE-6015- would be the same casting...before machining. For 289's that is. About 1200-1300 in existence for 1963. (all models)
