Projects Help F1 or F100 or something else Axle hub spindle Id -
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jul 3, 2016.
  1. Hackerbilt
    Hackerbilt
    F100 has a dip in the middle, F1 is flat...but shouldn't Ford truck spindles have the steering arm wrap up around from the rear?
    Are you sure thats Ford???
  2. deathrowdave
    deathrowdave
    from NKy
    Doesn't look like the Ford F1 spindles I have had , but been a while
  3. doesn't even look Ford to me
    Andy likes this.
  4. No I'm not sure it's ford, nor which one and That's why I'm asking.
    I have only seen those pictures and trying to decide if I want to drive 2 hrs to look at it.
  5. Any ideas if it's not a ford ?
  6. atch
    atch
    what's the bolt pattern on the wheels?
  7. 117harv
    117harv
  8. Don't know, all I have are those*****py pics. The wheels are 16"
  9. atch
    atch
    I've got some F-1 spindles and brakes that I can look at this afternoon and compare. However, by then there will have been 15 answers that will give you a definitive answer. H.A.M.B. rules, doesn't it?
  10. Hackerbilt
    Hackerbilt
    The axle has no dip...so if its a 50's ford its an F1. I don't think it is Ford at all.
    Heres a pic of the same side Ford F1 spindle/axle.
    Note the backing plate and also the steering arm. Also the shock bolt hole location and the curve of the axle out beside the kingpin boss.
    Everything looks totally different.
  11. seb fontana
    seb fontana
    from ct
    Chevy would be my guess..
