Technical Help finding '49 merc clutch lever bushing?
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Mar 19, 2026.
  1. This image is '40-'48 but I need the same bushing for a '49. In the diagram it is identified as part number 7517. It installs on the outside of the frame rail and rides on the cross shaft for the throw out bearing. It is secured by a cap that slides over the clutch lever. any help on locating one? thanks in advance. 574393013_2019767718864940_7000308725626426697_n.jpg
  2. J. A. Miller
    J. A. Miller
    from Central NY
    Check with @Mac VP at Van Pelt sales.
    51 mercules and alteredpilot like this.
  3. If you cant find the correct bushing a machine and bearing supply will carry stock size bushings that can be put in the lathe to get the correct o/d and reamed to the correct i/d if needed and then cut to the correct length. I know the correct bushing would be a lot easier, but sometimes ...
    Toms Dogs likes this.
  4. 24riverview
    24riverview
