Hot Rods HELP! Finding a Thread on Mopar Steering Box Mods
Discussion in 'The Hokey Ass Message Board' started by GearheadsQCE, Jan 7, 2024.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I have searched High and low with the HAMB search function and also Google to No avail.
    He posted a procedure for extending the sector shaft on a Mopar aluminum steering gear. He really cleaned up the box and mounting ears., cut and extended the output shaft, and made a (Br***?) nut on the input side.
    Quite an involved project. Thinking he might have been a machinist.
    IIRC it went in a Model A or 32.
    Since I have already searched every combination of descriptive words I can think of, (***les and all content) I believe it must have been part of a build thread and not stand alone.
    If anyone else recalls this, I would appreciate a link, or at least tell me that I'm not crazy! Also, if YOU find it in a search, please tell us what words you used. I've used up all mine!@#$%^&^$:D
    Thanx,
    Bruce
    HemiDeuce and seb fontana like this.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
  3. 34Phil
    34Phil
  4. RodStRace
    RodStRace
    You are not crazy. I don't remember the stuff you're describing. But you are not crazy.
  5. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Boy, the HAMB is slipping.
    Guys show a picture of a bent up piece of s**** iron and within minutes someone proclaims that it the radiator bracket for a 1911 Whippet. Followed up with another post that states that it was only used on the roadsters, as the coupes used a cast br*** piece.:eek:
    I can't even get anyone to admit that they even saw the thread!:D
    Well at least RodStRace confirmed that I'm not crazy. I'll be getting a second opinion on that!
    RodStRace likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    is this the one you are talking about?
    https://www.jalopyjournal.com/forum/threads/tech-cowl-steering.142985/
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Mark,
    That is not it. The one I' looking for had a bunch of work done to the box itself. T******* it down and cleaning up all the mounting point's etc.
    I've read through all the threads I could find referring to cowl steering hoping that maybe someone had linked to the one I'm searching for.
    Just seems to have vanished. I don't think it was real old and I believe I read it within the last couple of years.
    Thanx for the effort,
    Bruce
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @RodStRace,
    Beauty is in the eye of the beholder. Obviously you are damn near blind!:p
  9. RodStRace
    RodStRace
    gotcha! I deleted the post shorty after Moriarity posted.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I saw that, just wanted to let you know I caught it!:D
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    BTT
    I'm giving you guys one more chance to redeem yourselves. Somebody must have seen that thread or hopefully saved it!
  12. RodStRace
    RodStRace
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Thanx Rod,
    I've read everyone of those threads and the links within them. I believe that the one I am looking for must've gone to that big hole in the web.
    OBTW
    Is it Rod Saint Race or Rod Street Race?
  14. RodStRace
    RodStRace
    Bruce,
    There was one other from 2005 that had a reference to a previous thread which went nowhere. It's the first time I've seen a dead thread link here. Sorry. Don't give up.
    It was a riff on the character in Spinal Tap, David St. Hubbins and at the time I had a Rod project, Street car, and a Race car. So both, either, or. I've used it on a few different forums.
    Since I'm non blonde, I've used the likeness of Derek Smalls rather than David. Now that I'm gray, I've updated this recently. I have posted two pictures of my own face on the HAMB in the entire time I've been here (since 2007), so that mug to the left is the best you are getting. :D
  15. RodStRace
    RodStRace
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Nope! But I hadn't seen this one before. Like the coupling of 2 shafts.
  17. RodStRace
    RodStRace
  18. Mr48chev
    1935 Ron posted the photos of what he did in one of those threads. he hasn't checked in for 4 years though. I'm thinking that that is pretty well what the missing photos showed in the original post in that thread. Mopar mid size aluminum box, Schedule 80 seamless tubing , Original pitman arm cut down and machined to slip in the end of the hollow shaft, custom pitman arm that is welded on the hollow shaft in the correct orientation and a custom plate to cover the end. you also need a bearing (probably a pillow block) to support that shaft on a stout support just inside the side of the cowl. That wasn't shown. If memory serves right there was a pretty stout roll bar under the cowl that supported all of it.
    Photo creds to 1935 Ron.
    mopar cowl steering 1935 Ron.jpg mopar cowl steering 1935 Ron2.jpg mopar cowl steering 1935 Ron3.jpg mopar cowl steering 1935 Ron3.jpg
    69fury and RodStRace like this.
  19. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I have read the above except for the one by KOZ.
    He is still active here.
    @Koz, Can you post up the pics of the steering gear from your Sport Coupe Thread'?
  20. continentaljohn
    continentaljohn
    I know Mel did one when he was building his 1932 roadster. It was a great tech post.
    I’m very interested in this post as I have a few of them Mopar aluminum boxes
  21. Koz
    Koz
    Unfortunately I lost all my pics in a computer virus that wiped everything. I only have pics from the last year or so. I've done dozens of these and they work really great with just a little lathe work. Very important to keep everything nice and true. Also, I keep my bolt flange on the secondary shaft under the dash which allows me to use a more traditional pitman arm where it shows. Lately I've been more partial to '80's Ford manual pickup boxes as they do not require an extended shaft and mount up easier with more foot room. Also have a nice ratio for a cowl steer.
    I'd love to know who has the Sporty now. It just disappeared.
  22. Interested in more info and pics if you have time.
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @continentaljohn,
    I'm not sure who 'Mel' is. Can you elaborate?
    If I recall correctly, the thread that I'm looking for was a build on a think a '32 Roadster. That sure could be THE ONE!
    Thanx,
    Bruce
  24. alchemy
    alchemy
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @alchemy,
    YOU ARE THE MAN!
    THAT'S IT!!!!!!!
    Thanx everyone for your efforts. Now, I can sleep again :D:D:D:D
  26. Max Gearhead
    Max Gearhead
    from Wisconsin
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Something funny happened after studying the steering box mods for awhile. I decided to read the whole thread from the beginning. Turns out that @hotrodfab32 is one of my customers. He bought the side plates for his Halibrand and I remember him calling about the ribs on the Ford Trumpets and the Richmond R&P. Never put the two together until now.:rolleyes:
  28. RodStRace
    RodStRace
  29. hotrodfab32
    hotrodfab32
    Guess I'm too late
