Help?flatty or banger for my 28A ??
Discussion in 'The Hokey Ass Message Board' started by whiteyford, Jul 11, 2009.
  1. whiteyford
    whiteyford
    I need some opinions, its either the stock flatty with a mitchell od to get me on the fwy & out of town, or this 8ba with Granatelli heads/intake, with a t5 to banjo which means i have to have ladder bars, i think (ugh). Are there any better looking options for locking down the rear end with open drive?
  2. T.W.Dustin
    T.W.Dustin
    bangers are cool
  3. whiteyford
    whiteyford
    i agree, its been rebuilt about 1k ago, has winfield head and ansen intake/stromberg, suprisingly quick, and if i can squeeze another 10mph out of it i will be a happy man.
  4. saltflatmatt
    saltflatmatt
    Alliance Vendor
    V8 .... Those Grancor heads are beautiful and need to be used!
  5. whiteyford
    whiteyford
    see, thats the problem, i agree with you too....
  6. Weasel
    Weasel
    One in the front and the other in the rear?
  7. hombres ruin
    hombres ruin
    8ba...it looks killer
  8. V8 with 39 trans and the Mitchell OD and A rear.
  9. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    get an overdrive from a late model (49-54) ford.
    Neighbor has one in his daily driver 32 sedan, banger to boot!
    says it'll cruise 80 all day
  10. 97
    97
    8Ba with Mac's adapter and Crazydaddyo's 4wd Jeep T5 conversion with torque tube. Halibrand V8 diff .
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
  11. whiteyford
    whiteyford
    I was lookin at that setup, (jeept5)ust a little intimidated I guess by all the machine work involved, Also already got t5 and cornhusker adapter, guess I could sell and start over, wouldn't b the first time
  12. whiteyford
    whiteyford
    Will that allow me to keep TT?( behind 49-54 od)
  13. whiteyford
    whiteyford
    Uknow, I never really thought bout that. (Mitchell behind v8)
  14. Just Jones
    Just Jones
    Nope.
  15. 2eyed1940will
    2eyed1940will
    from new york
    Whiteyford, what are the carbs on your 3 carb set-up? I am puzzling over a set of mine. Thanks
  16. That is a great dilema to be in. That coupe looks killer, as does that v8. Either way, you're stoked!
  17. cuznbrucie
    cuznbrucie
    Yes....there is a better option for securing the radius rods with open drive.....
    Here: http://www.modelengineeringco.com/rearrodh.htm
    CB
  18. cuznbrucie
    cuznbrucie
    On your deathbed you will receive total consciousness.......so you got that going for you.........Goonga-Ga_Loonga...... ;^)
    CB
  19. whiteyford
    whiteyford
    thanks man:D
  20. Banger power with a t5 is the set-up. 65mph cruising speed. Sounds like you have a pretty stout set-up with all those speed parts. Why waste the oppertunity to join a minority with us moded banger folks? Do you follow the monthly banger threads at all?-Weeks
  21. tbraginton
    tbraginton
    from Nevada
    Ok this may be a really stupid question but is there an issue running open drive with radius rods?
  22. whiteyford
    whiteyford
    not if you have some type of torque arm, and the radius rods are unsplit, or at least not moved to the frame rails. you need to keep the radius rods triangulated to allow for independent rear wheel articulation, you also need a torque arm, or some type of locating device for your rear axle so it does not rotate due to torque. radius rods alone will not do this, may work for a while, but eventually, watchout!!!:eek:
  23. BCCHOPIT
    BCCHOPIT
    I WOULD BANGER HER......
    Bill
  24. A-Wall
    A-Wall
    flatheads v8's are the new sbc...
  25. The radius rods need to be welded up also that is one of the main things done with the conversion.-Weeks
  26. Algon
    Algon
    I'm biased toward ground t******* cars here but Bangers are really cool and less seen. The thing is a good built flatty, won't leave you praying for help just to merge onto the highway. I'd decide how slow do you mind going here and what you plan to use the car for exactly? I know what a stock banger is like aswell as a few with some speed stuff on it, I'd just be sure that's what you want before building it that way. Bum a ride in a banger car and see if that's what you really want...
  27. aldixie
    aldixie
    Go the Banger route. A lot rarer at the shows. I'm going banger with a T5. I think it will be more fun.
  28. Retro Jim
    Retro Jim
    The easiest way out is to build another for the flatty , that way you can have both !
    I would have a hard time also because they both are great either way . The banger is a killer the way it is now but the flatty really looks good too ! A flatty with 3 deuces and alum heads is really hard to turn down !
  29. whiteyford
    whiteyford
    already got a rebuilt(10 yrs ago) banger with winfield head and stromberg 97 on an ansen intake in the car, goes great till i hit the 55 mph wall.
  30. whiteyford
    whiteyford
    sorry, thought that went without sa;)ying
