Help frame rotten
Discussion in 'The Hokey Ass Message Board' started by pauls fords, Sep 13, 2010.
  1. pauls fords
    pauls fords
    I have a 55 ford 4 door and the front frame crossmember where the lower A arms attach is rotted out, anybody know where I can get one or someone have a bent frame[hit in rear] they would cut and send the front crossmember??????????? I beleive a 54 55 56 are the same.
  2. Gigantor
    Gigantor
    Try placing a request in the cl***ifieds wanted section.
  3. low budget
    low budget
    from Central Ky
    These cars are bad for that,you could box it up a bit and put a sraight axle under it:rolleyes:
  4. i believe Rod & Custom did an article on repairing one a few years ago
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Try google, I think thats a pretty common problem and I believe someone makes a repair panel for it. Few hundred bucks I think, but I am almost positive it's out there.
  6. pauls fords
    pauls fords
    LOW BUDGET thanks but it is a 4 door 55 and a customers car so a g***er won't do...
  7. Squablow
    Squablow
    53 is not the same, 54-56 is what you need. There is a repop replacement out there, I think it's kind of expensive, but it needs to be done.
    This is a super common problem with these cars, it might be tough to find a good replacement used.
  8. DOUBLEZO
    DOUBLEZO
    from SACramento
    i know they are far from you but, try big m in williams california. i was there over the weekend and they had a bunch of those cars in their yard. great guys to deal with too. 1-530-473-2225
  9. pauls fords
    pauls fords
    Squablow, thanks, I wasn't sure of the years so I eliminated the 53.....
  10. low budget
    low budget
    from Central Ky
  11. missysdad1
    missysdad1
    Try Chalupa55 here on the HAMB. He was talking a few months ago about jigging up to make them for HAMB members.
    If he can't help you, try Goodell Fabrications 918-636-7071. One way or the other you'll get what you need.
  12. dragass
    dragass
    Dennis Carpenter sells a repop for around $400.00.
  13. 56vicky430
    56vicky430
    from Kentucky
    Sent you an email. I ha a new one extra to my needs.
  14. Sounds like a good excuse to stick a clip or another IFS of some sort under there, actually. ***uming that can be done for the customer's budget, but at $400 for the part it might not make much difference versus a Jag IFS or a later car frame clip.
  15. Retro Jim
    Retro Jim
    Go onto the 52 to 56 Ford social group . There is a guy on there that builds them . Really nice work . Here is his HAMB name , Chalupa55 .
    Retro Jim
