Projects Help, Fuel Starved Carb??
Discussion in 'The Hokey Ass Message Board' started by BigBoltChevy, Apr 3, 2019.
  1. BigBoltChevy
    BigBoltChevy
    Let's try this again. Guys here have been extremely helpful. Full disclosure, I'm new and learning as I go. Ive now replaced the carb and now replaced the mechanical fuel pump on my 56 Cameo. Took a while, but fuel is finally starting to reach the filter, but doesnt seem like its making it to the carb yet. Being able to see the fuel has been a big help. I can get it to momentarily start by priming the carb (starter fluid or somw gas), but seems as if fuel is still not getting in. Not sure exactly what to look for now, just hoping the photos and video will help with your suggestions. Fuel seems to be coming from lower bowl, but I think its the fuel Im adding to prime, but not sure. Thanks in advance for your help
    Here's the video. Hope it helps. 20190401_185749.jpeg 20190401_185112.jpeg 20190401_185744.jpeg
    Sent from my SM-N950U using The H.A.M.B. mobile app
  2. squirrel
    put a can under the fuel pump, disconnect the hose from the inlet end of the pump, see if fuel pours out (it should). Catch the fuel in the can, of course.
    If that is not the case, then it's not getting from the tank to the pump.
  3. fastcar1953
    fastcar1953
    check for plugged fuel lines. tank to pump , pump to carb.
  4. oldiron 440
    oldiron 440
    Old fuel line from the tank to the pump can affect your fuel pump performance, it will draw air instead of fuel.
  5. RmK57
    RmK57
    Could the float is stuck down not letting any fuel in.
  6. fastcar1953
    fastcar1953
  7. Heavy Old Steel
    Heavy Old Steel
    Check the section of rubber line under the truck that connects the hard line from the tank to the hard line running to the fuel pump for cracks. Also in that first picture the clip is missing that holds the accelerator pump linkage in place on the top lever.
