Help get my car to the Pileup HAMBthrash!?
Discussion in 'The Hokey Ass Message Board' started by ruttencutter, Sep 26, 2004.
  1. ruttencutter
    ruttencutter
    I was really hoping that I would get my car ready for the pileup... and I think it's within reach, but only if I can get some help from some fellow hambers. I met up with several folks this weekend at Jefferson who said that they might be able to help with the 49' in the coming weeks. I talked it over with my wife, and she said it would be okay to have as many folks as I like over next weekend to get the 49 ready for the road.
    I figured I would post my todo list and see what you guys think. Is it doable? Can anybody make it down this coming weekend, Oct 1-2. I'll provide grub, drink, and a place to sleep (if needed). If we can get her up and running, I would love to make the Pileup my first trip out of this zipcode. Morris, IL is my wiifes hometown and it would make a great way to introduce the car to the inlaws [​IMG]
    By Friday I plan to:
    +ground to - ground conversion
    12v conversion
    New motor back together and running (302)
    Old motor & ****** out (If Bugman is willing to lend a hand)
    I need help with:
    Motor mounts (can order from speedway on Monday, or...?)
    Mounting the engine
    Mounting the ******
    Driveshaft to match new ****** (can probably get one made the week after the thrash if needed).
    Accelerator hookup
    Choke hookup
    Radiator (plug up 2 holes in the flathead radiator? [​IMG] )
    Exhaust Manifolds to exhaust (welded, or exhaust flextube [​IMG]
    Brake checkup
    Long list, but a few things there are pretty simple. Think it's doable? Can anybody lend a hand?
    Please help me get my car to the Pileup!
    Thanks,
    -Scott
  2. Levis Classic
    Levis Classic
    Got the same thing goin on with my 29 Tudor right now. Get to work!
  3. ruttencutter
    ruttencutter
  4. Might be able to help...!
    Got a welder and a torch handy...? (Don't need wrenches that way!) [​IMG]
    Mark
  5. fab32
    fab32
    Levi Cl***ic, Does that mean you won't be coming down to put the Cancy Apple paint on the 2dr before the Pileup? [​IMG] [​IMG]
    Frank
  6. hotrodladycrusr
    hotrodladycrusr
    Wish I lived closer to help. My fingers are crossed that you get it done in time BUT remember, do it right the first time. Don't give yourself an unrealistic deadline and do things half ***. Looking forward to meeting you at the Pileup no matter what you drive there. Good luck
  7. ruttencutter
    ruttencutter
    No welder, but I can get one.
    Torch on the other hand... I'm sure a hamber in the area might be able to help on that front.
    Wingnutz Let me know if that might turns into a will [​IMG] Know anybody else you might be able to turn on to the cause?
    As for doing things right--absolutely. I think it can be done--but if it can't, it can't.
    Thanks,
    -S
  8. Hey Scott,Good luck.I enjoyed meeting you and your wife this weekend at Jefferson.Hope all works out well with the motor swap.See you at the Pile up.
    Dan
  9. ruttencutter
    ruttencutter
  10. Thirdyfivepickup
    Thirdyfivepickup
    Keep at it! I wish me and the boys were a little closer...
    That list is doable in 2 days... 3 tops.
    With the right number of bodies!
  11. ruttencutter
    ruttencutter
    Thanks for the encouragement! So far, it's just me and bugman--***uming I can talk him into it [​IMG]
    Anybody else think they might be available?
    Thanks,
    -Scott
  12. ruttencutter
    ruttencutter
    Somebody? Anybody?
    I know it's short notice. If nobody can make it this weekend, I'm going to go ahead and call it off tomorrow.
    Thanks [​IMG]
    -S
  13. It's a "Will"...!
    Lets make it happen Cap'n...! [​IMG]
    pm'd you my number.
    Mark
  14. ruttencutter
    ruttencutter
    So I got two folks plus me. bugman and wingnutz.
    Anybody else who can make it down for friday night only, or saturday only, or sunday only? [​IMG]
    If I could get 2 more guys I think we could get it all done!
    -Scott
  15. ruttencutter
    ruttencutter
    Okay, I got one more guy. That makes 4!
    -S
  16. 2 more people and we can have a "Revolving Supervisory shift"...!
    Responsible for drinking beer and pointing to things that should be done... [​IMG]!
    How many carbs are you going to run...?
    [​IMG]Mark [​IMG]
  17. ruttencutter
    ruttencutter
    Just running a single 4bbl Holley, on an Edelbrock torker 2 intake.
    I still need to figure out what to do for an accelerator, since the throttle is on the drivers side, and at an angle.
    Any suggestions on how to adapt a throttle cable to a 49 guys?
    -S
  18. Sometimes if you get too many people helping things go slower... and you have a tall list of stuff to do in a week and a half... my advice is to prioritize and make lists of stuff that needs to be done.
    You are ***uming that you will not have any troubles fitting the motor in there... do you have a rear sump pan already? What about exhaust headers? I know the manifolds I had when I put a 302 in a '50 hit the steering box... I ended up going with 80's Mustang factory headers.
    What about wiring? To the coil... to the generator or alternator? What about your conversion to 12v?? Will you need to re-wire the whole car? 6v wiring is different.
    You'll need to have a drivehsaft made, or one cut down. So think about the u-joints... will they be different? Will you have to have the driveline shop mate two driveline yokes with one common tube?
    Floor clearence is also a problem... I had to make a ****** tunnel for the '50 I did. Then linkage? A floor shifter is the easiest...
    I also know the oil filter comes damn close to the frame on the drivers side... a remote adaptor off a Ford van works... but I ran the short filter and worked the frame in a bit with a hammer and torch.
    I take it you are going to take all next week off... and you have all the parts already bought... a drivehsaft guy on call as well as an exhaust shop on call...
    Not to burst your bubble... but if you get it done and driving there... I'll consider you a hot rod building GOD!
    Sam.
  19. ruttencutter
    ruttencutter
    Yeah, I have a rear sump pan, and pickup. I have factory exhaust headers and the pipes run to the engine compartment. The 49 has already been modified to take a merc-o-matic transmission, and the C4 is supposed to be a bit smaller so it should fit without firewall mods.
    The car has already been 'rewired', I just need to convert things to negative ground... and get drops for the gas gauge. And clean up whatever I have time for. I'm going to use a cheap set of gauges for everything else right now.
    I do need a driveshaft made, and was told if I bring the car in it shouldn't take more than a day or two next week.
    Maybe I'm missing something, but I think we can get the engine and ****** mounted in a weekend.
    -S
  20. Go for it!!
    Sam.
  21. ruttencutter
    ruttencutter
    So you don't think I'm off my rocker anymore ? [​IMG]
    -S
  22. Mart
    Mart
    Unless I'm forgetting something, the conversion to negative ground is no more than turning the battery round, especially if you go to an alternator.
    Just be careful you have no oddball accessories like a pos ground radio. The conv to 12 is more work.
    Have I forgotten something??
    To seal the holes in the rad unsolder the unwanted necks and solder correctly sized freeze plugs in place. Br*** if poss but steel will work.
    Mart.
  23. ruttencutter
    ruttencutter
    Thanks for the info mart!
    Now, 12V conversion means I need to change bulbs--right? Too much power for those bulbs?
    Thanks again. Any other tips guys?
    -S
  24. Thirdyfivepickup
    Thirdyfivepickup
    A remote mount oil filter might be a quick fix... rather than hacking on the frame. Sam is right... there is no room for a filter there!
    For a throttle cable... we used a Lokar and a chrome s**** pedal. Those Lokar cables will go anywhere!
    ...and yes, you are off your rocker! Welcome to the fun!
  25. ruttencutter
    ruttencutter
    Any chance I can pick up a remote filter at napa, or checker, or the like? What am I looking for exactly?
    And the throttle cable... do you have a url so I can look at what you are talking about? I'm clueless.
    Thanks,
    -Scott
  26. Tim
    Tim
    from KCMO
    yeah im sure you should be able to grab one at oreilys or napa, shouldnt be to hard to find
    good luck
  27. ruttencutter
    ruttencutter
    Thirdyfive got me lots of info on this.
    I'm glad somebody posted about the oil filter. This is the first time I've ever heard that it was an issue in there. Very good to know.
    -S
  28. Mart
    Mart
    Yeah, go round the entire car and change all the bulbs for the 12V equivalent.
    Mart.
  29. lilblondi
    lilblondi
    Just wanted to say thank you for all of your help! I've been running and calling all over to get the parts that we need. Oh, and I have actually been helping out a little in the garage too...even though I don't know much about cars, I just do what I'm told. = ) Anyway, thank you for all of your helpful information. And those of you coming out, thank you thank you thank you! I will be so excited once the car is up and running! (Even if it's not this weekend).
    Thanks again,
    ~Lizz
    P.S. for any of you that are really confused right now...this is Ruttencutter's wife. = )
  30. glassguy
    glassguy
    screw in expandable freeze plugs will get you goin if time starts runnin short . they have been a temp fix for years on my buddys car
