HELP!! GM Auto TRANS shift problem
Discussion in 'The Hokey Ass Message Board' started by dadseh, Jun 21, 2008.
  1. dadseh
    dadseh
    80s GM 3 speed auto.. wont shift out of first gear till I hit 35 MPH (60 kph)
    Any ideas??
  2. hoarder1212
    hoarder1212
    Do you have the vacuum line to the modulator valve hooked up? could be a problem with the governor also.
  3. sdluck
    sdluck
    What trans is it?
  4. dadseh
    dadseh
    Trimatic, the vac hose is on to the modulator also
    Q? If the modulator was stuck would that do it?
  5. madmak95
    madmak95
    the modulator ( little bell looking thing at the back of the trans on the p*** side) could be bad , stuck or hose bad. a new one isnt much and it has a set screw that will help set your shift points.
