Technical Help, help I lost a note book
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, Apr 10, 2017.
  1. OK here's the deal. I have misplaced a note book and it has an equation in it that I need.
    I am getting ready to figure the static compression on an engine that I need to screw back together. I haven't CCd the heads yet but I hopefully will in the near future, so I don't have all my info yet.
    Anyway one of you must have the equation I am looking for. I know that I need swept volume + deck height+ compressed gasket thickness etc.
    Does someone have that equation for me? please?
  2. vtx1800
    vtx1800
  3. Yep that one will do it, I would still like the equation for those times when I am not near a computer (I like running the slide rule to keep my brain sharp LOL) but that will get me to the same place.
    Thanks for the quick answer.
  4. Jalopy Joker
    Jalopy Joker
    - what system are running on your Notebook , Windows 10 or ? - Ha!
    brad2v likes this.
  5. Graphite its a very old system. :D
    powrshftr, brad2v and lothiandon1940 like this.
  6. squirrel
    slide rule?
    Larry T likes this.
  7. Yep still own a very old one. ;)
    Hell I never knew that it wasn't a toy until I took calculus.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    Where's FalconGeorge when you need him? ;)
  9. squirrel
  10. Relic Stew
    Relic Stew
    from Wisconsin
    Not a formula as such, but I can lay it out; (***uming inches for bore and stroke)
    Bore area = π * bore²/4
    swept volume = bore area * stroke
    deck volume = bore area * depth of piston at TDC (negative if above deck)
    gasket volume = gasket thickness*π * gasket bore²/4
    piston top volume, CC of dish and valve pockets or dome/16.387 (positive if dish, negative if dome).
    Head volume, CC of head/16.387
    Clearance volume = deck volume+gasket volume+piston volume+head volume
    compression ratio = (clearance volume + swept volume)/clearance volume
    If you want to get finicky, you can also add the clearance volume between the piston and bore diameters down to the top ring, but that's usually pretty small.
  11. I probably won't need to get finicky. LOL a tenth of a percent won't change my outcome much. :D
    Basically I need to ballpark static ratio to work toward a general fuel requirement. When I get that far I am probably going to need to lower compression just enough to be able to tune for pump gas. The plan is to stay on the ragged edge so that I can uptune for better fuel and quick short bursts of speed. Its a sort of a balancing act as I am sure that everyone is aware. ;)
    Now to add this to one of my notebooks that I can locate. ;)
