HELP!how do i remove masking tape glue &..!!!
Discussion in 'The Hokey Ass Message Board' started by banditomerc, May 24, 2010.
  1. banditomerc
    banditomerc
    I got this car that was taped with cheap masking tape,and after attempting to remove...it has left a glue on the trim as well as tape pieces all over!! is there an easy and fast way of removing this stuff.HELP:eek:
  2. El Gordo
    El Gordo
  3. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Go to the auto store and by 3m adhesive remover ,This product is the best .
  4. Boyd Who
    Boyd Who
    Goof-Off or Goo-Gone might help.
  5. KUZTOM
    KUZTOM
  6. 38FLATTIE
    38FLATTIE
    from Colorado
    Yep. Quick, easy, and everyone has it!
  7. temper_mental
    temper_mental
    from Texas
  8. moefuzz
    moefuzz
    Wax and grease remover, is one of the best and is available at any body shop supply.
    I guess this is a good example of why a person should only use 3M masking tape.
  9. trimless
    trimless
    acetone will remove it
  10. smiffy6four
    smiffy6four
    Yeah, it probably will, but it's not kind to paint or plastics.
    I use lighter fluid to get tape reside off. As pointed out earlier, if it's worth the cost of paint, then it's worth decent tape(3M).......
  11. Danny G
    Danny G
    Soak it with baby oil and let it sit , remove what you can and soak it again.
  12. Flamingo_57
    Flamingo_57
    from Rolla mo.
    Lacquer thinner. God's liquid gift to body shops. (As long as your car isnt painted with lacquer paint of course.)
  13. Scotts Enterprises
    Scotts Enterprises
    x 2
  14. dickster27
    dickster27
    from Texas
    Hey guys, it may very well not be cheap tape. If you leave masking tape on anything for an extended period you get the same thing, whether it's hi dollar tape or not. Go for the WD-40.
  15. henry29
    henry29
    All of the foamy widow cleaners in the metal spray cans dissolve it very quickly.
  16. 54oldie
    54oldie
    from Oklahoma
    x2 works great!
  17. junk
    junk
    X3 on 3M adhesive remover. Only stuff I use and lasts forever. I've got a can of it that is probably 7 years old. Still works awesome. Doesn't hurt paint and besides masking tape it also works good on duct tape, packing tape, stickers etc. On a really tough patch I use a plastic pampered Chef brown s****er to s****e most tape off then the adhesive remover to pull the final goo.
  18. Astrochimp
    Astrochimp
    from NE Mo.
    4x.
    It is what we use at the decal plant. Spray, soak, wipe.
  19. 1950merc
    1950merc
    from Butler, PA
    Don't get WD40 on anything you may want to repaint. Go for the prepsol and elbow grease.
  20. Gerrys
    Gerrys
    3M adhesive remover
    X5
  21. aaggie
    aaggie
    Spent a lot of years varnishing the Teak on sailboats and the tape left on for days in the Sun is very hard to get off. 3M makes a line of masking tape called "Sun tape" that is silver and you can leave it on for thirty days and it peels off without leaving any residue. It does cost more but the results are worth it.
  22. Steelsmith
    Steelsmith
    Sun baked tape does leave some nasty residue! You've got a pretty complete list of products that can take adhesive off. You've also got a couple of products listed in this thread that while they will remove adhesive will also wrinkle fresh paint! Those would be laquer thinner and acetone. I wouldn't use either of those anywhere near fresh paint!
    The 3M products for adhesive removal are pretty much fool-proof, just don't leave chemical soaked rags of the stuff on any fresh painted surface, you may get a bad reaction.
    There is one other chemical that works on adhesive that hasn't been listed here so I thought I'd include it. It's denatured alcohol. This disolves the adhesive and is considered to be quite mild as far as 'chemical burn' goes.
    The chemical burn list goes something like this:
    From hottest to coolest
    1) paint stripper
    2) laquer thinner
    3) acetone
    4) reducer
    5) mineral spirits
    6) wax/grease remover
    7) adhesive remover
    8) denatured alcohol
    This is not a definative list and from the mineral spirits on down they are considered to be quite mild for chemicals. That said, I'd still recommend wearing Nitril gloves because they all **** the oils out of your skin which can cause overdry skin/bleeding cracked hands with exposure.
    Dan Stevens
    dba, Steelsmith
  23. badgeree
    badgeree
    The Detailers at work use Prepsol. Works good and doesnt affect anything.
  24. Weasel
    Weasel
    I use Zippo lighter fluid or Goof Off. Soak it a little bit and then use the red plastic razor blades I get from Harbor Freight.
  25. skullhat
    skullhat
    ive always used prepsol or lighter fluid
    lighter fluid works really well, and gets it all off. works on labels stickers, just about anything, and wont hurt what you dont want to.
    wd40 works, but as said , dont get it around anythnig you might paint
    skull
  26. I use a product professional glaziers use on all sorts of glue stuck to gl*** called Super Seal release agent. Probably the same as 3m without the big name price. Safe to use around paint.
  27. banditomerc
    banditomerc
    Hard times i guess,i got a good deal on the car, so a little elbow grease on removing this tape/glue is cool.Thanks to all with your suggestions.:cool:
  28. zman
    zman
    from Garner, NC
    x6 good stuff
  29. abone1930
    abone1930
    What is the best masking tape to use while painting I can leave on for a couple of days?
    I have to mask my car in sections and I left me tape on for two days and was hard to pull off and left residue. Iused the 3m cheap stuff(lolwes), do I need to use blue or green 3m?
